Old 10-15-2008, 02:13 PM   #1
firzen
Spongy brakes
Hey all- got a question about my brakes. I recently rebuilt my entire brake system for my S5 T2, save the master and booster. Bled all four corners and the ABS until it the fluid was bubbleless and clear as day. Checked to see if nothing leaked or broke. Unfortunately, the whole thing is still spongy like a marshmallow.
Any tips and hints? I suspect it could be air in the master cylinder or booster but am not too sure how to go about getting the air out. I'm due for a state safety inspection soon and would like some feedback before I send it in.
Thank you.
Old 10-15-2008, 02:23 PM   #2
SpooledupRacing
Guest
Posts: n/a
sounds like either air in the system (back by the prop valve) or you have an inner seal on the brake master leaking..
I would do a gravity bleed for about 20 minutes per wheel and see if that helps, otherwise go back to every connection and make sure there is no leaks anywhere..
is the pedal spongy with the car on or with the car off or both?
could be a weak booster also.. another thing to check is the hose that goes from the booster to the intake.. make sure all of those connections are good and the hoses are in good shape.
Old 10-15-2008, 02:35 PM   #3
firzen
I did that, twice, just to be sure.
Both. It's already soft as heck when it's not on and when the booster kicks in when it's on, the pedal almost bottoms out.
Are you talking about the check valve when you say booster to intake hose? Haven't checked that yet but I will take a look later today...
Originally Posted by Low Impedance View Post
seems like the mazda love to eat master cylinders. i would look there.
I was afraid it would either be a booster or MC problem... Worst comes to worst, I'll redo the whole system and grab the 929 master while I'm at it. Will do a write-up if it ever goes that far...
Thanks.
Old 10-15-2008, 02:28 PM   #4
Old 10-15-2008, 02:37 PM   #5
BLKTOPTRVL
BLKTOPTRVL's Avatar
BLKTOPTRVL is on a distinguished road
Were the brakes done in the proper order?
...shoot a mother-humpin moose, eight days of the week...
BLKTOPTRVL is offline   Reply With Quote
Old 10-15-2008, 02:42 PM   #6
SpooledupRacing
Guest
Posts: n/a
in my experience if u bleed the system 2 times all around order dont mean anything really..
I have a stong feeling it is master cylinder since they are notorious..
if u need one let me know I got them for a good price (or try to)
Old 10-15-2008, 03:03 PM   #7
firzen
Yes.
Curses.
I'll take it to a shop and have them try bleeding the MC first then. Hopefully that will take care of the problem. If not, then we'll go from there.
Old 01-21-2009, 11:58 AM   #8
Nopis1O
Nopis1O's Avatar
Nopis1O is on a distinguished road
so what happened? i have the same problem only i replace the master and the booster also. i have bleed my breaks every possible way the still feel soft. The weird thing is on my sometimes they work perfect sometimes the suck which makes it really hard to autocross. any way thinking about getting an after market MC and going from there.
NEED UPDATE!!
1988 Fc Vert. Super Stock
1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
Nopis1O is offline   Reply With Quote
Old 01-21-2009, 12:26 PM   #9
firzen
I haven't gotten around to bleeding the MC yet but apparently the shop said that the brakes were OK. Heck, they even passed inspection.
I do intend to rebleed them come a few months as it is friggin cold where I'm at and I don't drive my car during winter months anyway.
If I were you and my brakes were that bad, I would not autocross just for safety reasons.
