Old 09-29-2008, 07:29 PM   #1
GreatShamanGT
GreatShamanGT is on a distinguished road
Need help!!!
Ok, so first thing's first. I bought a "Supra" Fuel pump. The reason why it's in quotes is because I question whether it's a real Supra TT Fuel Pump. Well here's a picture of what it looks like:
The main reason why I question whether it is a Supra Fuel Pump is because it says Walbro on the side. I was pretty sure that the Supra Fuel pump was Nippondenso wasn't it? This isn't a Supra Fuel Pump is it?
Also, here is how my engine bay sits right now:
Well, I've got some things that aren't quite connected yet:
Where does that hose go?
Also, for the ECU what does this line go to?
Thanks a lot for the help everyone.
GreatShamanGT is offline   Reply With Quote
Old 09-30-2008, 12:00 AM   #2
Brent
Sua Sponte
Brent's Avatar
Supra Pump is made by Nippodenso. If yours says Walbro, I'd say somebody ripped you off. I would contact the seller and inquire.
The hose looks like the coolant hose that connects to the throttle body.
Who knows about the wire. It appears it was spliced in by a previous owner for some reason. Only thing I know to tell you there is look up on the wiring diagram what the wire is suppose to go to based on the pin slot it goes into and go from there if you can't find the other end of the wire floating around on the passenger side floor somewhere.
Old 09-30-2008, 12:23 AM   #3
search for the factory service manual for a diagram about that wire.
