what fluid?
Have a LSD rear diff out of the n/a model that came with them, has the 4.3 R&P (GTUs?). Its a clutch type LSD, correct?
Question is, what fluid is recommended for this diff? Getting ready to install and gonna put fresh fluid in beforehand. What fluid and how many qts? thnx in advance |
10th Anniversary guy
clutch type, correct. book calls for 90 weight. i use royal purple.
80 LS 61K solar gold. 5spd 84 GSL 56K sunbeam silver 5spd 85 GSL 113K sparkling black 5spd 85 S 162K tender blue 5spd 85 GS 150K ocean blue 5spd 88 10AE 96K crystal white 88 TII 144K brilliant black |
Guest
Posts: n/a
I use 75w90 redline with the friction modifier (I think its called 75w90NS)
Rep Power: 21 ![]() |
you need to make sure it as additives for LSD. So look on the bottle to ensure its says "safe for Limited Slip" or something along those lines.
