Not sure if getting better, but Im porting a lot...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Bridge port VS. port original
![]() www.rx7club.com.ar RX-7 Forum in Spanish I make custom decals. Yes, you can ask me |
Rep Power: 21 ![]() |
whose template is that? have you checked to make sure you have enough side seal clearance?
#3 | |
Racing Beat by side seal clearance you mean the path of the side seal?
#4 | |
![]() damn! That's a difference.
yea
FB connaisseur
lookin good!
1983 GSL -nitrated plates, -SE housings, RX-8 E-shaft, REPU rotors, alum. flywheel, weber 45 DCOE 1983 GS -S4 13b swap. 60k miles, konig rewinds 1983 Limited-12a street port, 84-85 GSL rear end FOR SALE 1981 GSL - Minnesota mike built Street port 12a with solid corner seals , TO4B turbo, MSD 6A, E-fan, GC coilovers, tokico illuminas, RE-speed strut bar, corbeau seats, simpson 5pt. harness, Kosie K1 15x7's, falken 205/50's, sevens only watts link, 11psi 1981 S - bone stock, 47k miles |
#8 | |
Temporarily insane.
That thing is going to be making some good power, I have a feeling. Looks good, but do you have any closer pics of the ports? I'd like to see how smooth you've made them.
For my collection of short stories: Kindle Nook |
#9 | |
In the half bridge, I went with a 180 grit finish, cause I´ve read Judge Itos recomendation to go that way if you use nitrous
#10 |
your fine...like i told you in your other thread...Your bride is good...As like in your other thread bring the bottom of the bridge down even with the bottom of the main port...You are going to feel the difference in performance for sure.
One Turbo At A Time
#11 |
Thanks Teddy.
I`ve been working on my bridge following your sugestions. I also got the Mazdatrix dvd on porting, and Im using a few of their tricks as well
#12 |
mirror finish is not everything but quality and efficiancy is what counts...post pics with your progress
One Turbo At A Time
