Old 05-22-2014, 10:33 AM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
Wiper problem
I'm in a bit of a pickle. My mist/int/II setting on the wipes has stopped, while the I setting works still. Looking through wiring diagrams, it appears the settings that quit all use the intermittent wiper relay, which my guess has given up the ghost.
Where is this relay located?
Old 05-22-2014, 10:36 AM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
Isn't the relay in the wiper switch itself? I thought that's what the "wiper fix" was - replacing the relay. I've got an extra switch lying around from the silver car (S4). I honestly don't know if it completely works or if a S4 switch works in a S5 car.
Old 05-22-2014, 10:43 AM   #3
MolotovMan
GTUs
MolotovMan is on a distinguished road
The relays are inside the wiper switch itself. You have to take it out and take it apart to replay the relays. Unfortunately, they can't be cleaned and only replaced.
You'll need to have decent soldering skills to replace them because once you've taken the switch out and taken the plastic off you need to heat up the solder points and split the boards to gain access to the relays.
I have seen someone offering rebuilt switches or a rebuilding service on ebay for $60 or so.
MolotovMan is offline   Reply With Quote
Old 05-22-2014, 11:30 AM   #4
http://fc3spro.com/TECH/HOWTO/WIPER/wiper.html
Old 05-22-2014, 11:37 AM   #5
chibikougan
chibikougan's Avatar
Hahhahaa! ^^^ Posted same link Ted has ninja post on!
Old 05-23-2014, 05:28 AM   #6
tweiss3
Mazda Lover
tweiss3's Avatar
Can anyone tell me if the S5 and S4 switch are interchangeable? I'd love to pick up a spare incase I screw up somehow.
Also, any idea which relay is bad by my description? That write up says there are three.
Old 05-23-2014, 11:33 AM   #7
chibikougan
Relay 3 is the one you want to replace. I am not sure if they interchange. They have very non rear wiper, regular non rear wiper, and very. In S4 and S5
Old 05-23-2014, 11:41 AM   #8
Wiper switches are grouped via series, so there are different part numbers for each...
I know for sure the headlight switches are NOT swappable, although the plugs do interchange.
Mazda had the bright idea to redo the fricken' pins; the change is in the sub-harness that plugs into the headlight switch itself.
Stupid.
This might be the case with the wiper switches...?
Try and find out and report back to us?
Old 05-22-2014, 05:05 PM   #9
tweiss3
Mazda Lover
tweiss3's Avatar
Well, that answers all my questions. More difficult than I had hoped, but I can manage that.
Old 05-22-2014, 06:35 PM   #10
chibikougan
Get a couple extras and go to town!
Old 05-23-2014, 12:26 PM   #11
tweiss3
Mazda Lover
tweiss3's Avatar
Well, I ordered the relay, we will see how long it takes for that to show up. I figured it was worth the 15 buck before caving to another switch. I may get that S4 switch and try it just to find out if they are interchangeable, although since the headlight switch is different, I have my doubts.
Old 05-23-2014, 05:00 PM   #12
chibikougan
Mazdatrix lists all the models and has a different one for everything.
Old 05-27-2014, 07:40 PM   #13
tweiss3
Mazda Lover
tweiss3's Avatar
Wow, relay came in today. I guess that means this Saturday I will break into the switch. I did not expect it to come in that quickly.
