Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 04-16-2008, 02:49 AM   #1
Factory Service Manual: FSM* + MORE
Well, I did a quick search and didn't yield anything and I figured I'd get it started.
POST LINKS OF ANY READING MATERIAL THAT YOU THINK IS INDISPENSABLE TO THE AVERAGE ROTARY HOBBYIST.
Notify Poster If Any Links Are Broken.
Old 04-16-2008, 02:52 AM   #2
This link has a ton of great reading material that should not be missed!!
someone should make something like this for this forum. hint hint. You never know when a site like this will be gone a la iluvmyrx7.
too bad no html is allowed.
Old 04-16-2008, 03:27 AM   #3
Ender
rotors excite me
Ender's Avatar
www.rotorwiki.com
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 04-16-2008, 06:24 AM   #4
My5ABaby
My5ABaby's Avatar
My sig...
Which, in case I change it someday, is:
Community Service Manual
RotorWiki
RotorWiki
Old 04-22-2008, 05:21 PM   #5
Iox106
Iox106 is on a distinguished road
Front oring fix
http://www.mazdatrix.com/faq/oring.htm
Iox106 is offline   Reply With Quote
Old 04-22-2008, 05:26 PM   #6
Ex-Eg-Driver
Ex-Eg-Driver's Avatar
Ex-Eg-Driver is on a distinguished road
Thank you for the easy access information!
87 RX-7 BASSSEEEEEE Red
Ex-Eg-Driver is offline   Reply With Quote
Old 04-22-2008, 05:38 PM   #7
Anytime man.
Here is a GREAT Article on the IGNITION SYSTEMS in the FC.
HOW-TO: Make Your Own LED Code CHECKER/TPS Tuning Light.
HOW-TO: Tune Your TPS Using the Multi-Meter Method.
Old 04-23-2008, 07:12 PM   #8
KGParts' Injector Info
Old 04-25-2008, 05:53 AM   #9
AwakenNoMore
AwakenNoMore's Avatar
AwakenNoMore is on a distinguished road
get a parts ordering list up here! (the big book with all the fc part #'s)
1993 VR Touring, motor built by Arizona Rotary Rockets.
AwakenNoMore is offline   Reply With Quote
Old 04-25-2008, 01:07 PM   #10
http://rotarycarclub.com/rotary_forum/showpost.php?p=18335&postcount=2
The parts catalog is in there too^^
Old 11-25-2008, 11:10 AM   #11
yeti
yeti is on a distinguished road
I don't know if it it's good information but I'll put it out there.
pretty much it's a list of parts from other cars that replace rx-7 parts.
Anyone can add or change information... but since it's been born only one other person has touched it and I think they just changed a year range.
http://spreadsheets.google.com/ccc?k...LFM7zFbQ&hl=en
1989 vert, RB header and presilencer (looking for a catback), SAFC-II, custom fiberglass speakerbox, 130 amp alternator sweetness.
Parts Interchangeability List
yeti is offline   Reply With Quote
Old 04-25-2008, 02:09 PM   #12
Also, I just noticed your sig, congrats on the Modified Magazine article. Told you it was One-of-a-Kind even if you hate it's imperfections.
Old 04-28-2008, 12:39 AM   #13
FC: Wheel Fitment (offset and bolt patterns)
Old 11-18-2008, 09:26 PM   #14
Mike had an issue and I remembered this:
http://www.1300cc.com/howto/how2/rewire.htm
Turbo II fuel pump rewire
First off I would like to say a few things, get yourself a real Mazda service manual. I managed to do mine with just a Hayne's but it was a pain in the ass. Some of the wire colors did not match and I had to constantly check between Dale Clarks write up (see below), My Haynes manual, answers to my questions on the FC3S mailing list, and my voltmeter readings. Also if you look at the diagram in the haynes the order the wires leave the relay do NOT match the order of the wires at the 6 wire connection!!!.
I have taken this write up from Dale Clark's page (http://rx7.freeservers.com/modhb/rewire.htm) and added a few things (in red) as well as some pics:
**note: Non turbos are different becuase they don't have the resistor relay that changes the
voltage, which makes things
much, much easier!**
Why rewire the fuel pump?
- Even on a car with a new alternator, new battery, new battery
terminals, and clean electrical connections (mine) I saw as low as 10v to the fuel
pump with a load on the system (lights on, stereo cranked, heater on, etc.)
- The fuel pump should, under boost, be seeing at LEAST 12v.
Reduction in voltage=reduction in fuel flow=bye-bye motor.
Considerations when rewiring the pump...
- First off, it should operate as normal. You turn on the key and go; no extra switches, etc.
- The fuel pump resistor circuit should continue to work. This drops
the fuel pump voltage to 9v at idle and cruise to improve fuel economy.
- The safety switch in the air flow meter should continue to work.
The airflow meter, when closed, turns off the fuel pump. So, if you roll the
car, you won't be pumping gas out of the car at 30-40psi making a big fireball .
Some caveats about doing this job -
1. This is NOT EASY. If you are comfortable with 12v electronics (you've wired up a few
stereos) you should be able to do this. You need to test everything as you go along. If
this doesn't work, your car will not run. If you really hose it up, you could have inadequate
fuel pump voltage. I WILL NOT TAKE ANY RESPONSIBILITY - you broke it, you bought it.
2. I'm also assuming that you know all the standard procedures for wiring stuff - solder your
connections, heat shrink tube or electrical tape all bare wire, etc.
3. Just take your time with it. It's really not that hard, but there's a lot you have to keep
in mind. It took me the better part of an afternoon to do, most of which was double-checking
and triple-checking my theory on how stuff is going to be hooked up.
OK, so how do you do it?
You'll need -
- a 12v automotive relay (Radio Shack - "30 Amp Auto Relay", cat #275-226)
- about 15 feet of 12 gauge wire
- an inline fuse for the 12 gauge wire
- about 20 feet of speaker wire (you need two wire runs to the back
of the car, and speaker wire has 2 wires)
- various crimp-on connectors (to connect to the relay and positive
battery terminal)
- electrical tape
I used about 23 feet of speaker wire running it up the passenger fender, across the fire
wall, and up the driver side door way. I probably used more then 15 feet of power too.
Never hurts to buy more.
I used 10 gauge power wire and 12 gauge speaker.
You will also want a soldering iron. I soldered all my connections.
OK, first off let's run the wire. The speaker wire needs to start at
the airbox location in the engine bay and end by the driver's side rear shock
tower. The 12 gauge wire needs to come from the postive battery terminal to the
same spot (don't hook it up yet! Hook the inline fuse between the positive
terminal and the 12 gauge wire - you always want the fuse close to the
battery. I used a 15 amp fuse, and it seems to be adequate. You might want to run both wires
at the same time - makes it a little easier.
Next, it's time to move the resistor and relay. Remove the airbox.
There's a metal bracket that has a relay and a aluminium box that looks like a
heat sink. It connects to the wiring harness with a large rectangle white
connector.
Don't worry, you only want one of these
connections
Let's label these wires, as per the shop manual. Diagram below is
on the relay/resistor side:
____--____
| E C A |
| F D B |
On my 89 turboII (canadian if thats makes a diff) A,C,E were all blue w/ red strips
B and F was blue w/ green, D was green w/red
OK, cut the connector off the wiring harness. Leave enough slack on
both sides of the cut - we'll be re-splicing the connections in. Connect the
speaker wire to C and D (one wire to C, the other to D).
Old 11-18-2008, 09:27 PM   #15
Part 2
So, now you've got your resistor and relay with a cut off connector.
Move to the back of the car. Remove the driver's side rear speaker assembly
and the plastic trim above where the jack goes. Pull the covering on the
side of the hatch area forward.
At this point you might want to pull out the fuel pump to clean the little filter on it.
It was pretty easy. or you might want to change the pump for a high flo one
just remove the 4 screws holding the cover, pull out the wire connection. pull off the gas
lines (might want to depressurize frist) undo the screws underneith, and gently pull out
the pump. I just ran the filter under water. I am sure there is a way to take it off but
mine was pretty clean so I didn't bother trying.
On the side of the shock tower closest to the
rear of the car is a wiring harness with a white connector. This is the
connection for the fuel pump. There's 4 wires there - 2 for power and ground, and 2 for
the fuel level sender. On the fuel pump side of the wiring, the two topmost
thicker wires are power and ground. I believe power had a white stripe and
ground is just black. You might want to test it first and make sure you've got
the right wires. Cut both of them about 6 inches down from the connector - you
might need to cut off some of the covering around the wires. Time to hook up
the relay.
yes the pump power is a black wire with a white strip, ground was straight black. the other 2
I had were red and blue, both were smaller and for the sending unit.
Here's what you want to do - use the power lead that normally comes
into the fuel pump and the ground on the car side of the wiring harness to
turn the relay on and off. Run the 12 gauge wire from the battery terminal into the
relay.
The relay has 4 connectors. Two are for power and ground to activate the relay, and the other
is the circuit that the relay activates. The lead that normally activates the fuel pump should
go to switch the relay on, with the opposite connector going to ground. The output from the
fuel pump resistor relay (see below) goes into the 3rd connector, with the lead to the fuel
pump going to the final connector.
here is my relay (wraped in lots of tape I ran the 10 gauge power in from battery and out
to resistor. I used the stock + and - wires that I cut off the fuel pump connection to turn the
relay off and on. you can see my speaker wire going back to the resistor. The green wire is
the power wire from the resistor to the pump. notice the shrink wrap, also a good idea.
Time to wire up the resistor relay. Take the wires from terminals A
and E and splice them together. Take the wires from terminals B and F and
splice them together. Attach the speaker wire you ran from the front of the car
to terminals C and D (one to C, the other to D)
(same ones as in the front). Run a wire from
the relay (the opposite terminal that the 12 gauge wire is on) and attach that to terminals
A and E that are spliced together. Run a wire from the spliced terminals B and F to the fuel
pump positive lead. You can ground the fuel pump separately or just
attach it to the same ground wire it used in the past on the harness.
I grounded the pump in the trunk with black 10 gauge as you can see in above pic.
After you get the fuel pump resistor relay wired up, make sure to put it in a spot where it has
plenty of "breathing room". It gets REALLY got and can melt the insulation off wiring (as
Bruce found out). I nylon-tied it in the area where the antenna motor is; it's just got metal
around it, nothing meltable.
This is a pic looking down into the trunk to see my resistor. I just undid a nut there, held
the resistor and put the nut back up to hold it. the resistor is in open air and I moved the
connection higher with a zapstrap as the wires were touching it. To answer your question "why
is there 2 greens?" it is because my red 10 gauge power from the realy only goes half way to
the resistor, then changes to the smaller green one. this was because i only had a tiny bit
of wire left at the resistor connection and figured it would be easier to splice thin wire
in instead of 10 gauge.
OK, go back to the front of the car. There should be 4 extra wires
where you cut the resistor relay off. Splice the wires that were on A and B
together, and the wires that were on E and F together. This lets the signal from
the main fuel pump relay travel back to the fuel pump area, and it activates
the relay there to bring the new 12 gauge wire online with the pump.
Time to test it. Get a jumper wire and jumper the fuel pump check
connector - it's a yellow two-prong connector on the passenger's side shock tower
in the engine bay. It might be buried a bit, so keep looking. After
jumping the connector, turn the key to "On" (don't start it) and go back to the
hatch. You should hear the fuel pump running. If not, check your wiring for good
connections.
I was very happy when mine turned on first try. Now as long as everything stays connected...
Yes, this is a VERY complicated procedure, and you have to keep a lot
of things straight. If you have a shop manual, turn to pages 4B-70 and 4B-71 -
there's a really nice diagram of the whole setup there, along with a diagram of
the fuel pump resistor relay. This job took me just a Saturday afternoon.
I cound have really used one of these diagrams ah, It took me a sunday afternoon, evening
and night...
The prinicpal of the idea is moving the fuel pump resistor relay near
the back and splicing a relay carrying a REAL voltage into the equation. This
method keeps all the factory safety features (air flow meter cutoff, check
connector, etc.) It also allows the resistor to function properly. When the
relay for the resistor is open, all the current goes through the resistor and is
dropped to ~9 volts. When the relay closes, it makes a path with no resistance
through that part of the circuit, and we all know that electricity takes the path
of least resistance.
Results? Well, I'm now seeing over 13v at the fuel pump with no electrical load at wide open
throttle. With stereo cranked, headlights/foglights on, AC blowing, etc. I see about 12.5
volts. Sweet!
If any part of this is unclear, please let me know. It's a pretty
complicated procedure with a lot of wire-deciphering, and I think I got the gist
of it down. This procedure is VERY necessary with upgraded fuel pumps and fuel
pressure regulators as Bruce Lewis found out - the stock wiring just can't
deliver enough current. Hopefully this $10-20 mod will help save some modded
engines out there!
after I read all this the first time off Dale's site I was confused and a little bored I sat
down and made a diagram to make things make sense and seem alot clearer and easier.
I don't
have a scanner so it's just a dig pic of a piece of paper.
