Old 10-04-2013, 05:00 AM   #1
bowjangles
bowjangles is on a distinguished road
How old is my 13-B?
Greetings:
I have a unknown year 13-B engine in my '80 Tr-7 roadster. It has a Hitachi 4bbl. carb on it. The engine number is B63798. How can I tell what year the engine was made? Really hard to get parts w/o this information.
Second question is: Do the holes on the black plastic throttle body spacer (under the carb) face up or down? My guess is up because the little tubes from the oil metering pump enter it from the back, but would like confirmation.
Thanks for your help in this matter.
bowjangles is offline   Reply With Quote
Old 10-04-2013, 10:14 AM   #2
My5ABaby
My5ABaby's Avatar
http://www.banzai-racing.com/faq_housings_ID.htm
Any of those fit? If not, http://en.wikipedia.org/wiki/Mazda_Wankel_engine#13B , there's a couple other options but someone else would have to chime in as to how to tell them apart.
Community Service Manual
RotorWiki
Old 10-05-2013, 05:28 AM   #3
bowjangles
thanks I'll check that out
Old 10-04-2013, 11:09 AM   #4
Pictures are worth a thousand words.
Also, the script on the housings can tell quite a bit.
Old 10-04-2013, 05:37 PM   #5
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
if it has a hitachi it is likely a 74-78, i don't see why anyone would bother trying to make it work on a late series 13B.
74-75 had the old slanted MAZDA logo(all capitals), the 76-78 engines have the traditional logo used up until current.
http://rotaryevolution.net
Old 10-05-2013, 05:32 AM   #6
bowjangles
how old is my B-13?
If, by logo you mean the word MAZDA on the engine block, then it must be a 76-78 engine cuz the word is in upright (not slanted) letters- is this correct?
Old 12-27-2014, 02:47 AM   #7
ACE Rotor
ACE Rotor is on a distinguished road
Please help identify my motor (13b)
Hi guys, plz help i.d where my 13b is originally from.
it has pollution gear on it.
my car is an rx7 series 2 and originally came with a 12a.
id like to know the year the 13b is from so i can look up ignition timing references
i suspect the breakerless ignition with 2 vacuum advance units on it are from a 12A?
are the dizzis interchangable between 13b and 12a?
ACE Rotor is offline   Reply With Quote
Old 10-04-2013, 06:21 PM   #8
Or, it could be an old script engine that was rebuilt with newer housings like mine.
But, like Rev said, Hitachi means its old school, 4 port NA 13B (in theory)
Old 10-04-2013, 07:56 PM   #9
Rotary Evolution
rotaryevolution.net
yes, it could have any mix of parts up to 1985, maybe even beyond but the ports are bigger on the late engines and the hitachi wouldn't even be close to ideal and would require adapters for the intake/carb to work.
Old 10-04-2013, 10:14 PM   #10
wackyricer
wackyricer is on a distinguished road
yup
wackyricer is offline   Reply With Quote
Old 10-05-2013, 03:20 PM   #11
rxtasy3
rotary madness
rxtasy3's Avatar
rxtasy3 is on a distinguished road
74-75 large framed "mazda" script.
rxtasy3 is offline   Reply With Quote
Old 10-05-2013, 05:49 PM   #12
Rotary Evolution
rotaryevolution.net
and all beyond that have this style script with some minor variations:
sorry, not many hits with the logo came up at the top..
Old 10-06-2013, 05:15 AM   #13
bowjangles
how old is my 13-B?
Here is a pic of the Mazda logo from my 13-B.Using the info and pics that you sent me the engine can't be a '74-76 because the word MAZDA is not in slanted script, right?
So, we are getting closer to finding out the age of this engine.Are we now sure that it was made from'76-78?
I just found a complicating factor. When I ordered a new manifold intake gasket from Racing Beat Inc. I matched up fotos of available gaskets with my old gasket and it matched perfectly with #of a gasket that fit a '74-75 13B. Now I'm, really confused.......What year can the engine be?
Old 10-06-2013, 11:03 AM   #14
Rotary Evolution
rotaryevolution.net
it is probably a 3B REPU casting block with the short primary runners, the housings look like 76-78 year castings. i believe even the 76-78 model year REPUs still retained that early 3B small port design.
there should be a cast number/letter on the front iron under the water pump with either a 3B or a Y, Y is the tall primary runner casting for the cars.
Old 10-07-2013, 06:45 AM   #15
bowjangles
I found a number under the water pump as u said I would. It is a "4". Does that help us determine which year it was built/ What it came out of? Don't know what a "primary runner" is. Thanks for taking the time to help me with this
