Old 02-11-2013, 11:07 AM   #1
verb.zero
verb.zero is on a distinguished road
Rear diff mounts
Okay so recenlty I traded my n/a for a TII that had idle issues which I solved. While driving the car I noticed the front rear diff mount is blown, im not trying to be cheap but I dont want spend $100 for a new one... I have heard of people welding the diff mount, what is the pros and cons of doing this?
verb.zero is offline   Reply With Quote
Old 02-11-2013, 12:13 PM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
Are you talking about welding the two "halves" of the front diff mount together to essentially make a solid mount or welding the mount to the diff itself? I don't see why the former would be a problem as long as you're confident in the weld. Personally, I don't like having solid diff mounts though as a little movement takes stress out of the drivetrain.
Old 02-11-2013, 01:18 PM   #3
My5ABaby
My5ABaby's Avatar
You can probably find a used diff mount that's still usable for pretty cheap. That'll most likely be easier than welding it and give a better ride.
Community Service Manual
RotorWiki
Old 03-28-2013, 07:14 AM   #4
DerrickS
Spot's Driver
DerrickS's Avatar
DerrickS is on a distinguished road
Your should get rid of that complicated rear end setup and just install a solid axle...
I did notice some burnout marks at the top of road, so maybe you got this fixed already?
Derrick
84 RX-7 five letter
"It's better to go into a corner slow, and come out fast, than to go in fast, and come out dead" - Sir Stirling Moss
DerrickS is offline   Reply With Quote
