Old 07-24-2012, 04:12 PM   #1
therex
therex is on a distinguished road
car smoking
I know you guys have probably have heard this before but my car is smoking now, kinda bad.
it smokes at startup, sometimes at idle, and while im driving, car starts up great, and drives great too, not sure where its coming from, just wondering where i should start looking, eats a lot of oil, probably a quart a week ( i dd it)
not sure if its the turbo or oil control seals...?
coolant levels havent changed either
therex is offline   Reply With Quote
Old 07-24-2012, 04:35 PM   #2
therex
there is a small oil leak, and theres oil on the bottom of my turbo and wastegate from a bad oil return line, have pics
Old 07-25-2012, 01:14 AM   #3
Mazdabater
FC3S
I'd pull the turbo and check it out. Might help to pray first if your religious lol. Sounds like alot of smoke though for it to still be running fine. Your coolant level won't drop unless you've done a coolant seal, and even then it's pretty slow.
Old 07-25-2012, 02:53 AM   #4
therex
Lol i will but honestly what am i looking for, and anything else i should be looking for?
Old 07-25-2012, 05:45 AM   #5
Where is the smoking coming out from?
Under the hood?
From the exhaust?
Is the smoke from oil?
Smell the smoke...
If it burned your eyes, it's oil.
If it's sweet smelling, it's coolant.
If it's under the hood, then it's a leak somewhere...
You need to replace the gasket or tighten the fitting.
If it's the exhaust, then it gets a bit more involved...
It could either be the engine or the turbo.
How much miles on the engine?
If you're around 200,000 miles, the engine might need to be rebuilt - no way around it.
If it's the turbo, then the turbo needs to be rebuilt.
One quick test is to pull the spark plugs...
Are the they are cruddy and wet with oil?
Good chance the motor is no good; minor chance the turbo compressor seal is bad.
Pull the intercooler pipes and intercooler - lots of oil pooling inside?
Turbo compressor seal needs to be replaced - i.e. turbo rebuild.
I don't see oil leaking from the turbine section - usually that's an indication of the turbine oil seal going bad.
It might be the seal hasn't totally let go and is only a minor leak so far.
You're not getting too many responses, cause your posts and descriptions so far are very vague.
Old 07-25-2012, 03:09 PM   #6
therex
Under the hood?
From the exhaust?
Smell the smoke...
i know i know, sorry
yes the smoke smells like oil and is coming out of the exhaust, not the hood
engine shouldnt have more than 20k on it but i honestly dont know
i had the spark plugs out a couple days ago, i dont remember them being wet
and already checked the intercooler pipes for the TB side, no oil. should i check the other side?
and i drove the car yesterday and it barely even smoked, but the night before my friend was behind me and i could see the smoke because of his lights
thanks ted
Old 07-25-2012, 07:33 PM   #7
Mitchocalypse
Mitchocalypse's Avatar
Mitchocalypse is on a distinguished road
that might help you diagnose your spark plugs. how long after start up does it take for the smoke to appear? any external leaks? (puddles on ground)
Mitchocalypse is offline   Reply With Quote
Old 07-25-2012, 08:56 PM   #8
therex
lol those are all rancid, theyre just normal and black, not oil tough i dont think and right when i start it and no puddles, and smokes when i take off ive never seen it when i was driving
Old 08-07-2012, 04:15 AM   #9
therex
bump have the turbo and ex mani off, no oil in the manifold, dont really know what to look for now
Old 08-07-2012, 05:34 AM   #10
Pete_89T2
Pete_89T2's Avatar
Did you do the 4K RPM in neutral test Ted mentioned before taking it apart? If so, what were the results? No smoke, little smoke, lots of smoke?
Old 08-07-2012, 07:30 AM   #11
Is the turbine wheel on the back end of the turbine housing *BLACK*?
Old 08-07-2012, 12:30 PM   #12
therex
gahh i forgot to do it! but ive done something like it before, i never looked for smoke but i could smell it a bit, and it definately smokes more when i go into boost.
and no its actually white? ill post a pic
Old 08-07-2012, 12:41 PM   #13
therex
Old 08-07-2012, 02:08 PM   #14
If the car is smoking, it isn't smoking that much...
I assume the exhaust ports on the engine / turbo exhaust manifold has color about the same as the turbine wheel?
If so, that's good and bad.
Good that it's not a major failure of the oil control rings on the engine.
Bad that we cannot narrow it down to either the engine or the turbo - the oil leak isn't that bad yet.
Can you take apart the turbine housing off the turbo?
It's just the 6-bolts that are along the inside of the turbine housing facing the turbo center housing.
Those should be 13mm (or 1/2") bolt heads.
If you can take that off, we can inspect the area between the center housing and turbine heat shield.
Just to make sure we cover all the bases...
You did check the intercooler pipes and intercooler for signs of oil pooling in there, right?
Old 08-07-2012, 03:26 PM   #15
therex
Lol it was getting annoying though and yeah i can take it apart but i dont really want to haha would i need a new gasket? And yeah i looked at the exhaust ports, really clean, obviously black from exhaust though, no oil , no oil in intercooler pipes a guy on a local forum said it looked wet around the turbo shaft rear seal?
