Old 06-02-2011, 10:54 AM   #1
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Door Handle replacement with pics
Thought I’d do a write up on this considering our craptastic plastic door handles
Remove rear triangle piece from door. It has 2 clips that hold it on so be careful not to just yank it off and break those clips. I usually work from the top and edges.
Behind that you have 1 10mm nut and 1 10mm bolt
You should be able to slide the handle out just a bit to see the 2 rods behind it. 1 is to the lock and 1 is to the handle. You'll want to push the plastic clip to your left making it swing clockwise (This is all from the perspective of you standing outside the car looking in) to release the rod
The other rod will need to go right or counter clock wise
You should now be able to see behind the door handle (blah that pic came out bad). There are 4 screws holding the door pin down.
I just pulled out 2 of the screws and loosened the other 2 so that I could move them out of the way. Once moved out of the way push the rod out that holds the handle in place
I fished around for a while trying to get the new handle in without success i eventually had to take the screw out of the opening piece that the thicker rod went into (I have no idea what the name of it is)
Fish in the new handle and hook everything back up. This is what was causing mine not to work right
Add any tips if you have any.
Old 06-02-2011, 04:13 PM   #2
RX7 RAGE
RX7 RAGE is on a distinguished road
Thanks for sharing as I'm gonna have to do this too.
RX7 RAGE is offline   Reply With Quote
Old 06-03-2011, 03:18 PM   #3
millertime
addicted to boost
millertime is on a distinguished road
Thanks for posting these here, what was the deal on the big forum?
millertime is offline   Reply With Quote
Old 06-03-2011, 09:49 PM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I've had a few issues with the way Mar3 deals with things. I've PM mods and reported posts nothing has changed. He went to far so i pulled my stuff.
Old 06-06-2011, 04:45 PM   #5
yzf-r1
Banned
yzf-r1 is on a distinguished road
There was another vendor selling a replacement handle...
yzf-r1 is offline   Reply With Quote
Old 06-07-2011, 10:57 AM   #6
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
http://www.rx7doorhandles.com/
Old 06-14-2011, 11:35 PM   #7
yzf-r1
Banned
Originally Posted by Force13b View Post
Yep, that's what I was looking for....thanks
Old 06-10-2011, 11:22 AM   #8
Signal 2
Viable Fossil
Signal 2's Avatar
Mar3 is a nut-job/ass-hat. Double sizing his font aside, he started into some nonsensical political rant about WalMart being like the Nazis....in the NEW MEMBER section of all places. He's costing them. You go to that section now and the only ones posting answers (about FDs anyway) seem to be other mods.
Nice write-up btw. The pictures should be helpful to anyone taking them out for the first time...even if they're not broken. The black exterior of the assembly tends to get beat-up over time with key nicks etc. Taking it off and disassembling it would be preferred if you've ever considered having them re-painted.
Jim
VR R1 FD
Old 06-03-2011, 09:40 PM   #9
prrex4ever
prrex4ever's Avatar
Great write up, thanks.
