Old 12-27-2010, 08:49 PM   #1
13bboy
13bboy is on a distinguished road
starting problem
i had my window down in my t2 and i walked outside to put it up, turned the ignition barrel to on and pulled the electric window switch up, my dvd player turned off the window did not go up and it started to make a buzzing noise coming from the LHS of the engine bay, now the car wont start, i turn it to on the buzz starts then i turn it to start the buzzing stops but nothing else happens dosent even try to start.
any advice is appriciated
thanks
13bboy is offline   Reply With Quote
Old 12-27-2010, 09:22 PM   #2
You have a dead battery or the main relay isn't getting the juice that it needs. But seeing as how the engine won't turn over and shit dies when you ask other shit to turn on, Ima say dead battery
Old 12-28-2010, 07:21 AM   #3
13bboy
you were correct it was the battery, i didn't think about it because it's only about a month old. Now to find out why it's dead
Old 12-28-2010, 09:00 AM   #4
My5ABaby
My5ABaby's Avatar
I'd check the voltage of the battery. It could be the battery terminals not making a good connection.
Community Service Manual
RotorWiki
Old 12-28-2010, 01:06 PM   #5
Definately could be corrosion or a bad ground, usually is. Hook up an Ammetter and make sure the A's are about .25. If it's higher start pulling fuses till you find the closed circuit.
Or it could be a bad alternator. Girl came into work one day and while we were all on our 3 o'clock coffee break she told me that about 1/2 way to work, every time she hit the brakes, the radio would go out.... I thought about this for a second and told her that the alternator died. Everyone laughed. 2 days later she came back to work becuase the car died on the way home and sure as shit it was the alternator. My diagnostic skills were legandary after that point
Old 12-28-2010, 04:25 PM   #6
MmSadda
BOOSTED COLON
MmSadda's Avatar
MmSadda is on a distinguished road
TitaniumTT is just legendary, period.
MmSadda is offline   Reply With Quote
Old 12-29-2010, 12:07 AM   #7
13bboy
thanks for the help guys, appriciate it
