Old 12-16-2010, 04:20 PM   #1
Judge Ito
Porting Master
Judge Ito is on a distinguished road
Goopy Performance resurfaced rotor housings,THEY WORK!!!
I have been working with Jon from Goopy Performance on and off for many years. Many times we have different views, but when he comes up with something that works, well I have no choice but to post some of my results and experiences. Jon has perfected a way of resurfacing used rotor housings. I mean this is pretty impressive considering most of us throw away rotor housings that he brings back to life. I will post pics of before and after.
Back in late 2007 Jon came over to me and asked me to try some crappy rotor housings he had resurfaced. I looked at them and said "Jon this will not work" Jon said: "Ito just try them". To give you guys an idea, those housings were grooved pretty bad by the outer edges of the housing and the trailing plug area were full of vertical grooves .(a common problem) and pretty much garbage. I Put 1 engine together using his used resurfaced housings with New oem 2mm apex seals. After 200 miles of driving I gave the engine a compression test @ 195 degrees of coolant temp. The engine gave me 125-128 psi with a conventional compression tester.
Since then I have put a few engines together with Jon's resurfacing. The better the housings are to start with, the better the resutls. The FIRST THING I NOTICE IS THE REALLY GOOD FLAT SURFACE after the resurface. On my last engine I did a compression test and pulled 131-132psi using his 2mm apex seals. I was stunned to say the least. I'm here applauding Jon from Goopy performance not for perfecting this resurfacing on other wise rotor housings we would have thrown in the garbage, but for his continued hard work to improve all kinds of minor and great details this engine has to offer.
for info. you could pm me.. I'm a skeptic that turned into a believer. congrats Jon.
pics of before.
AFTER
enjoy
Judge Ito is offline   Reply With Quote
Old 12-16-2010, 05:11 PM   #2
RICE RACING
Don Mega
RICE RACING's Avatar
They look great
Are they running on the SS liner after removing those very deep marks? do you have any pictures of a housing that has run say 20,000 miles on OEM seals & high power after this process has been done.
What is the cost.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-16-2010, 05:25 PM   #3
Judge Ito
Porting Master
They look great
What is the cost.
Yes I have an engine apart, after this resurface. i'll take pics soon. price is 125.00 us dollars. for you aussies you figure out the difference in mula. that includes the cleaning of rotor housings.
Old 12-16-2010, 10:53 PM   #4
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
that looks amazing seems to be cheap as well.
mazdadude7 is offline   Reply With Quote
Old 12-17-2010, 12:42 AM   #5
Kentetsu
Kentetsu's Avatar
Great info! (should really fix the spelling in the title though)
Welcome aboard Goopy!
Old 12-17-2010, 10:45 AM   #6
Spectacular. I always wondered if this could be done, and hoped someone would figure out how someday. LOVE IT!
Old 12-17-2010, 11:12 AM   #7
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I can't really tell on the before pics, but was there any flaking of the
surfaces on the edges of the housings or were they just scratched and scored?
Old 12-17-2010, 05:23 PM   #8
Judge Ito
Porting Master
those particular rotor housings had no flaking to begin with, just grooves. grooves were eliminated and a flat surface was achieved.
Old 12-17-2010, 04:47 PM   #9
jerd_hambone
Senior Member/Lounge Rat
jerd_hambone's Avatar
Is that a coating on there, or is that just a really clean housing?!
1986 Luxury Package
1987 Luxury Package (sold)
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
jerd_hambone is offline   Reply With Quote
Old 12-17-2010, 05:24 PM   #10
Judge Ito
Porting Master
no coating, just a grinding of the surface.
Old 12-17-2010, 04:58 PM   #11
2gslse
Impressive would like more info as well
Old 12-17-2010, 05:27 PM   #12
Judge Ito
Porting Master
i'll have jon come and shed some info. on this. over all it's a homerun.
Old 12-17-2010, 07:57 PM   #13
Ian
REIAN
Ian is on a distinguished road
So this process will not get rid of the corner seal wear from the three piece seals? I have a few housings that have this wear. More or less the chrome is flake right off..
1989 Turbo II. Track Car
1988 10thAE. Garage Queen 400+rwhp
Ian is offline   Reply With Quote
Old 12-18-2010, 10:06 AM   #14
Judge Ito
Porting Master
no it will not, but if you decided to use rotor housings in that condition(many of us have) including myself. this type of work will only make those type of housings seal better. that's why i say, it's a homerun. you can't loose. the better the housing, the better the result, but a better rotor housing will come out of this resurface even if it's flaked.
this is a video of my kid's turbo II. her daily driver. this engine had rotor housings with flaked edges. Jon did the resurface for me. 3 years later engine(ported) pulls 12inches of vacuum and run's 13's all day on a stock turbo, stock ecu, ect,ect.
http://s254.photobucket.com/albums/h...Picture017.flv
Old 12-18-2010, 10:09 AM   #15
Judge Ito
Porting Master
engine@ idle.. 750 Rpm's 12 inches of vacuum on a decently large streeport..
http://s254.photobucket.com/albums/h...Picture012.flv
