Old 10-08-2010, 06:12 AM   #1
hades
cleaning up the engine bay - airpump / fan refurb
So. I am replacing my water pump, thermostat and doing a bunch of other maintenance items to the car.
My air pump looks like trash - well normal i guess. I don't want to remove it permanently yet. But I do want it to look better. Have any of you taken the clutch / pulley off, or the hose connections or the back plate?
I also want to make the plastic fan shroud look better than it does. Any suggestions for paint?
This is going to tear
Old 10-19-2010, 05:54 AM   #2
Signal 2
Viable Fossil
Signal 2's Avatar
Originally Posted by hades View Post
....I also want to make the plastic fan shroud look better than it does. Any suggestions.....?
Tire foam. Spray a little on, wipe off excess if you can with a paper towel and let it dry. Makes underhood plastics and rubber look new w/o that gooey look you see in the used car lots.
Jim
VR R1 FD
