| 3rd Gen RX-7 Cars For Sale Buy or Sell your Car only!! No Parts! |
1993 Touring (Highly Modified)
Due to some financial obligations, I am forced to sell my 7 year project. I bought this car back in 2003 when it was bone stock. Now, the car has come a long way. It dyno'ed at 462 rwhp / 358 rwtq @ 18 psi on pump and meth injection and 417 rwhp / 330 rwtq @ 15 psi on pump gas only. You get full boost at around 4k so it is quite fun to drive. You can email me at Legerba@gmail.com or message me as well.
Engine Mods Rebuilt, street ported motor with 2mm aviation seals (Approx 15k on rebuild) T04Z Turbo kit (2) 1600cc secondaries and (2) 850cc Primaries and all supporting fuel hardware i.e. Aero FPR, rails, and fittings Dual Nippendenso Fuel Pumps Coolingmist Vari-Cool Controller Kit for Meth Injection GM 3 Bar Map Sensor ACT Counterweight ACT Streetlite Flywheel Spec Stage 4 Clutch (6 puck) B&M Short Shifter Fluidyne Radiator 3 row Greddy Front Mount Intercooler HKS SSQV BOV HKS Twin Power Ignition Amp Power FC with Commander DEFI Boost Controller Greddy Pulley Kit HKS Hiper Exhaust with a midpipe Battery Relocated to the driver's side rear bin Exterior Mods Feed Sideskirts '99 Front Lip '99 Spec Efini Wheels with centercaps (Note: One wheel is damaged) Fresh Paint that is about 2 years old Drivers side door latch is aluminum Converted the rear tail lights to '99 spec Suspension Mods None Drivetrain Mods S4 T2 Differential Bad Front lip has some wear and tear on it 5 gear syncho is bad so it grinds going into 5th. Turn Signal lever does not work as in it will not active the turn signals. You can still activate the turn signals by reaching around the lever and using a manual switch. The features on this switch still work i.e. headlights. The steering column is broke because someone tried to steal the car =( Drivers seat has a little wear and tear. No keyless entry and the key does not unlock the doors. Stock radio does not work very well. All speakers are blown. Drivers side plastics are busted (typical) A/C has been removed Extra Parts that will be included but I have not installed yet RP Toe Links RP Trailing Arms H&R Lowering Springs Pictures can be found here: http://s1024.photobucket.com/albums/y308/Legerba/Rx-7/ Asking price: $10,000 OBO I need this car sold ASAP. I have the title in hand and I am ready to sell. If you have any other questions, don't hesitate to ask. I live in St. Louis Area (Swansea, IL actually) if that helps. |
Sorry about the post count of 1 but I am new to this site. I usually hang out on the rx7club.com message boards...
#3 | |
Administrator
Rep Power: 10 ![]() |
you have to start somewhere, thanks for listing it on RCC. Good luck with the sale!
Kevin
#4 | |
WNC Tour Guide
Back to a Rotary again
Email sent for pictures.
