| Rotary Of The Month Contest Every Month we are going to pick a car and rotorhead to be featured as RCC, Car of the Month. At the end of the year, we'll select car of the year and prize will be given. |
Rep Power: 21 ![]() |
July 2010 Turbo/SC FC Nominations!
Nothing says indepedance day like boost. So submit your half way to christmas, turbo or supercharged FC nominations!!!
(next month NA FC)
destroy, rebuild, repeat
i will nomiate my 10th AE:
![]() 60-1/p-trim bb S5 hybrid, 15psi arc topmount 3" RB exhaust streetport, RA superseals haltech e6k, 750cc/1000cc, walbro 255 ACT HD PP, steet disk, ss clutch hose tein flex coilovers stern 16x8 wheels slotted rotors, ss braided hoses aerodynamic dent mod
1993 RX-7 Touring MB, stockport 13B-REW, 9.4CR rotors, T04S 60-1/p-trim single turbo 1986 RX-7 Base project track beast |
keep them coming
Rep Power: 10 ![]() |
I'll play
![]() ![]() And I nominate Rotordad's SC'ed widebody........
Big Ugly
Rep Power: 17 ![]() |
Thanks man, you own one of my favorite FC's. I guess I can add a pic or two.
Boosted Big Body On 335's PS3 ID: Rotordad 1986 Mazda RX7 GXL - Street ported 13BT, Haltech, 62mm, ect. 2006 MazdaSpeed 6 - Eagle, Wiseco, Cobb, ect. |
I nominate my 1990 Turbo 2:
![]() ![]() ![]() ![]() ![]() ![]() Engine: 13BT w/ Large Street Port, 2mm cryo treated apex seal Blitz Blowoff valve Auto EXE/Gruppe M intake w/ custom piping HKS top mount intercooler Apexi N1 Exhaust Random Technology "high flow" Catalic Converter RE Amemiya Racing Wires RE-Amemiya Oil Filler Cap RE-Amemiya Radiator Cap Koyo Radiator Samco silicon radiator hoses Mazdatrix Aluminum water pump filler neck Mazdaspeed Oil Pan Baffle Mazdaspeed Motor Mounts Transmission: Exedy Stage 2 street/strip clutch and flywheel C’s Racing Short Shifter Mazdatrix Aluminum Driveshaft Mazdaspeed Competition Transmission Mounts Mazdaspeed Competition Diff Mounts Mazdatrix Stainless Steel Clutch line ARC Shift knob Suspension/Braking/Wheels: DG5 Coilovers Energy Suspension Polyurethane bushing replacements Cusco lower arm bar RE-Amemiya Front Strut Mazdaspeed rear strut bar Racing Beat Sway bars Brembo cross drilled/power slotted brakes Custom powder coated calipers Corksport Stainless steel brake lines 17x 8 +35 RE Amemiya AW-7 17x 9 +35 RE Amemiya AW-7 Falken Ziex Electronics: Apexi Power FC standalone w/ hand commander Apexi Limited Edition Turbo Timer (mounted in the ashtray) Apexi Earth Stabilizer Kit RE-Amemiya boost gauge w/ Greddy gauge pod mount Clarion MAX675VD 7” Touch face Monitor Clarion NAX970HD Navigation Unit Interior/ Safety: RE-Amemiya Sport Seats w/ Mazdaspeed rails RE-Amemiya Steering Wheel RE-Amemiya Harness Pads Safety 21 LHD 5 point cage custom powdercoated Cusco blue from Cusco Japan Trust Harnesses NRG quick Release Hub Momo Steering Wheel Hub Attachment Custom Carbon Fiber idiot cluster surround Last edited by sugoi_fc; 07-10-2010 at 12:09 AM. Reason: forgot to add specs |
I'll self-nominate my mostly stock but well restored '89 RX-7 Turbo Coupe. With the exception of paint work and an "ABS delete" mod (done to deal with a leaky ABS pump), all work was done by yours truly.
Some basic car info, major restoration history & mod list: VIN # JM1FC3321K0701200, Build date: 01/89 Purchased used in May '99, I'm the 3rd owner. Currently has almost 135K miles on body; 45K miles on rebuilt engine. (Hayes Rotary reman w/new housings). - Painted in 2001 by Perfect Bodies Auto Collision, Longbranch, NJ - Restored leather seats in 2005 - Installed new Mazda engine wiring harnesses, 2008 (BTW - this is the BEST investment you could ever make in a 20 Y.O. RX7!) Engine/Drivetrain Mods: - RP Downpipe (pre-cat delete) to stock main cat, Borla SS cat-back dual exhaust - RP heavy duty clutch - Corksport SS oil cooler lines - MazdaTrix short throw shifter Suspension/Brakes: - Racing Beat springs - KYB AGX 4 way front/8 way rear adjustable struts - Hawk HPS brake pads all around, Brembo stock OEM replacement rotors; complete rebuilds of all calipers & brake hydraulics 2009 Miscellaneous: - Sony radio/CD player & Kenwood speakers (circa 2000) - Autometer Boost/Vac gauge on A-pillar - Glowshift Oil Press, Water Temp and Oil Temp gauges mounted in DIN panel under radio. |
Bah!
Geez, so many nice cars in here! I'm not gonna throw my bastard child in
Johnson TA FC in the works! |
#9 |
Another hard decision, best of luck to all.
#10 |
rotary powaaa
I nominate Allen a.k.a. Rotarybeat1287 and his super clean 87 TII
#11 |
Home-brew Rotary
^ here's a old picture.
![]() ![]() And *bump* for more nominations and/or poll.
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. |
#12 |
Home-brew Rotary
And a slightly better picture of 88turboii's 10ae.
#13 |
Did I miss something? Where does one vote?
#14 |
Big Ugly
#15 |
sorry the air force jacked me up for the last couple weeks, can some get the poll up? my internet options are limited.
