| 20B/3 Rotor Conversion.. All things to do with 20B/3 rotor... Post pics, video, tech, etc.. |
#1 | |
N/A 20b build
So I've been emailing back and forth with Adam from RX7Specialites in Calgary, AB about a 20b N/A build. It seems like he wants me to do a ton of extra things that I don't know if I need or not. Basically, I'm going to be building a fun street car that I will take to HPDE once in a while. What I want is a large streetported 9.7:1, balanced to 9000RPM engine. He wants me to go with new housings and says new rotors are a necessity. Do I really need all of this for a 300whp N/A build?
He suggested the following in an email... Quote:
I know he knows what he's talking about and I'm sure it would be a KILLER engine. But... it's all about dollars and cents. What do I need to build a 350whp ITB'd street ported 20b? I'm going to be runnign a Microtech, have some equal length headers built by a friend who is a fab king and most likely use the Hinson subframe with their bumpsteer kit. Any input would be appreciated. ![]() Thanks... Aaron from Canada |
Can't.Make.Up.My.Mind.
You dont need Bridgeport. and it you want as a street car dont. im going to be doing damn near the exact same build as you soon. my goal is the 350whp area as well. my mods to start are.... 20B engine/large street port/Rx8 10.0:1 compression rotors/balance rotating assembly/cryo treatment/ and stocke 20B UIM to start with. Eventually switching to a single 90mm TB which will free up some ponies and then if im still feelin froggy ill do ITBS. With all the mods i just listed (which sound very similar to what you want) 350ish whp is attainable. Ive talked to alot of people and done the research. But if anyone has something else to add lmk.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
#3 | |||
The only upgrade would be to go FD bearings. Not necessary if redline is set at 9k RPM's. It is debatable about balancing the oil pick-up and districution system, since the engine is so long... I'd go at least with an upgrade OPR and call it a day - if you're paranoid, run the FD or 100+ psi OPR, and you should be fine. "Race bearings" are unnecessary unless you're planning to go over 9k RPM's... Scalping rotors? Sounds like they are trying to rip you off be charging you for expensive / unnecessary mods. Bridge port is not really necessary... We were able to hit 230hp at the wheels on a DynoJet with the STOCK block, STOCK intake, and a too-small air filter: http://fc3spro.com/PROJECTS/SKY/20B/20bna01.jpg The car could've gotten close to 250 if the air filter wasn't too small. The stock intake is not meant for normally aspirated applications. 300 at the wheels is a realistic goal... Quote:
Short intake system Tuned header and exhaust system All the proper safety mods to support those power levels -Ted |
Thanks Ted
Sounds just like what I was thinking. I am kind of paranoid so race bearings might be nice or at least new OEM ones and a balance of internals. Oil pressure is important so this might be something to go for as well. Who would you recommend to get this work done by? -Aaron |
I wonder what I could even get out of fully stock block with ITB's?
Hrmmm... maybe I should to that FIRST to get the car up and running, set up the way I want then get it built for more power? |
Mazda Competition (now Mazdaspeed) used to sell "race bearings"...
Guess what they were? Stock Cosmo bearings...which your 20B already has. These are the "3 window race bearings" that you see. I believe Racing Beat sells them as such also? The only better bearings are the stock FD ones which are "9 hole" bearings and, I believe, deeper groove? Sorry, I can't recommend anyone for your 20B build. I do all the work myself. ![]() -Ted |
#7 | |
I think the reason they were talking about race bearings is because they were gonna build a 3 rotor istead of using a 20B block to start with. Just FYI sending you a PM btw |
#8 | |
You interested in building mine?
#9 |
Interested?
Sure. ![]() You do know I'm from Hawaii, right? ![]() -Ted |
#10 |
The Ancient One
Sounds like a good general plan to me. I would suggest you go with a 90mm throttle body instead of ITB's with a large street port. The street port runs out of steam at around 7500 rpm. You are totally constrained by the stock throttle body. There are plenty of 90mm throttle bodies you can mate to the intake. You should be able to make close to 350 with that. If you want to go higher, you really want to go pport (or semi pport)and ITB's.
Gordon
1993 Rx7 R1 20b NA 1994 Rx7 20b supercharged project 1991 BMW 850 6 speed 1991 BMW E30 M3 Evo II |
#11 |
Ah... like building a 20b out of 13b parts with a 20b e-shaft...
Hrmm... Still doing re-seach. I may just find a good block and throw it in the car, get it running on stock comp ratio rotors and stock ports then once the car is running and all the parts fabbed up get the engine sent out. |
#12 | |
#13 |
He said to get new 13b housings, because 1) they're new and 2) they already have the FD exhaust insert.
#14 | ||
Half bubble off plumb
if you are going to be spending that kind of money to build a motor, even more so a 20B its not a bad idea... then you know you have a completely fresh pallet to start with.. not wondering if the second hand housing, or irons were abused, or overheated, or whatever...
Adam @ 7 specialties knows his stuff.. but I also know quite a few guys from the Calgary area that will not let him touch their cars... everything I "know" about that place is all second hand info, so I wont post any of it.. but I will say that he is one of the most knowledgeable people in Alberta when it comes to Rotaries... he does like to make high dollar builds though... I'm hoping in the near, or distance future to do a build very similar to this one... maybe even 26B, if the funds are there when I go to build it... but either way... looking forward to the running log... where are you located BTW... if you are somewhere close I would offer my help if you ever needed it.. currently I live/work in fort mac.. but that might be changing soon cheers J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#15 |
That's the thing... I DON'T really want to spend that kind of money. I just want a solid, reliable 300whp N/A engine. Simple.
I'll do some oil mods from which I've read help with high revs for the center bearing but nothing else other than balancing I really think I need? |
