Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 02-24-2008, 09:59 AM   #1
HDP
HDP is on a distinguished road
Rebuildable Cores
Just wondering if 99 spec turbos can be used as stage III core.
HDP is offline   Reply With Quote
Old 02-29-2008, 12:21 PM   #2
Bryan@BNR
Bryan@BNR is on a distinguished road
yes they are good for cores for a stage 3 build up. I will not use the abradable comrpessor housings for the stage 3's. The nylon insert doesn't have enough meat to fit the larger compressor wheel, plus the nylon insert unreliable anyways. Take it easy.
Bryan@BNR
Bryan@BNR is offline   Reply With Quote
Old 02-29-2008, 10:47 PM   #3
80 CID
80 CID is on a distinguished road
Is there any advantage to using a 99-spec for a stage 3 core?
80 CID is offline   Reply With Quote
Old 02-29-2008, 10:56 PM   #4
Bryan@BNR
The only things is the turbine housings have added nickel to help with the cracking isssue.
Old 03-01-2008, 03:16 AM   #5
TRISPEEDFD3S
TRISPEEDFD3S's Avatar
TRISPEEDFD3S is on a distinguished road
Wow...I've never known that...can those be purchased from Mazda?
My Cardomain!
http://www.cardomain.com/ride/2179693
TRISPEEDFD3S is offline   Reply With Quote
Old 02-29-2008, 11:01 PM   #6
80 CID
I'll keep that in mind. Thanks for the quick answer.
Old 03-01-2008, 07:54 AM   #7
WOW! I never knew that either.
Old 03-01-2008, 08:27 PM   #8
RX7 RAGE
RX7 RAGE is on a distinguished road
that's good to know
RX7 RAGE is offline   Reply With Quote
Old 03-07-2008, 07:18 PM   #9
rotarymandan
rotarymandan is on a distinguished road
That is good to know. But is the housing being nickel really worth the extra money compared to a good set of 93 turbos? Either way, I definately see a set of BNRs going on my car sometime in the future...
rotarymandan is offline   Reply With Quote
Old 03-08-2008, 02:15 PM   #10
Bryan@BNR
No its not worth the money. When I build the 3's, I radius all the sharp corners that are proned to cracking. If the 99's are leaking or have problems, then they would be a great core to use for the conversion.
Bryan@BNR
Old 11-22-2010, 07:52 PM   #11
HDP
What is the turnaround time on a set of stage III?
Old 11-27-2010, 02:08 AM   #12
porschepilot79
porschepilot79 is on a distinguished road
Great info! One thing im wondering is if its a good idea to cyro the turbine housing to make it stronger to stop cracking? Also, If the housing is cracked should that not be used for the upgrade? Thanks!
porschepilot79 is offline   Reply With Quote
