Old 04-22-2010, 11:23 AM   #1
infernosg
IT'S ALIVE!
infernosg's Avatar
Possible 4-Port N/A Start?
So for the longest time I've wanted to do a 4-port N/A build on my '89 GXL. I've found an engine locally for a good price that may be a good candidate, but I'm not sure. It's a '88 TII engine w/ 100k miles on it. I'm told it holds compression but the coolant seals are gone. I'm really only interested in the housings as my plan consists of swapping in a S5 front cover, RX-8 e-shaft and some S5 N/A rotors (RX-8 rotors would be nice, but I've heard there are timing issues?). Ultimate plan would be a streetported or bridgeported motor with ITB's and being controlled by a PS1000 or Sprint RE.
I'm just curious if I should be weary of the coolant seal failure even though I will be rebuilding the engine from the ground up. Also, are there other incompatabilities between S4 motors and the S5 chassis I should be aware of?
Old 04-22-2010, 06:24 PM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
So I'll want to hold onto the S4 front cover, water pump, water pump cover and OMP it seems. Either that or swap everything over from a S5, but I didn't want to have two engines pulled apart at the same time so I could actually still drive the car
Seller mentioned one or more of the coolant o-rings have failed, but that the engine still ran. Waiting to hear back from him so I can go check it out.
Has anyone else gone retro-active with a S4 motor in a S5?
Old 04-22-2010, 09:06 PM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
EDIT: nvm...
Why can't I delete my own posts?
Old 04-22-2010, 10:18 PM   #4
I don't believe there are any timing issues with the RX8 rotors. Same physical dimensions--just higher compression ratio and that comes in the tub.
Coolant seal failure motors are a crap shoot. It could just be a simple seal gave out and it hasn't done any damage to the housing. However, when my coolant seal crapped itself, the actual housing that held the groove for the seal had been removed/fell out/eroded away. Depending on how the seal went bust the engine may have been over heated.
There is minimal incompatibilities between the S4 and S5 motors (I'm currently running an S5 rear plate since my S4 took a crap)
You can swap what ever you want from any gen 13B except the renesis. The trouble comes when you want to use alternate versions of the same engine. IE you can't go between an S4 and S5 front cover and oil pump/distribution block. A little research could help you out with the details.
It should be fine. It's the same basic engine, it's just the OMP is mechanical instead of run via a stepper motor (and a few other odds and ends).
EDIT: nvm...
because you're not 1337! You has no powA' here!
Old 04-23-2010, 08:23 AM   #5
infernosg
IT'S ALIVE!
infernosg's Avatar
^^^ Figured as much. I know I could easily just swap the front and rear covers from the current engine in and call it a day. Only reason for considering the S4 front was because of the mechanical OMP, which I'm on the fence about keeping and I don't really want to have to pull the current engine and have the car down for the entire duration of the build.
The RX-8 rotating assembly is tempting - I just thought I read somewhere (probably RX7C) that the RX-8 rotors weren't necessary a good change, despite the increased compression, which is something I'd like to have.
Hopefully will be checking out engine today. May also be picking up the transmission as well (don't know if I'm going to use it or not though).
EDIT: Still debating between a small bridgeport (not cutting into water jacket) or large streetport for the motor. I've read a lot on both and am still not decided. Can anyone make a case for either?
Old 06-15-2010, 12:03 AM   #6
SLIDN2
Self Proclamed Genius
SLIDN2's Avatar
SLIDN2 is on a distinguished road
Half Bridgeport TII engine NA (loving it).
BRAP BRAP BRAP BRAP...
SLIDN2 is offline   Reply With Quote
Old 06-15-2010, 06:14 AM   #7
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
I basically have the exact engine you want to build with a half bridge. Only difference is I have old school 4 port irons and housings. The half bridge is nice, makes really good power even at lower RPM. Mine still isn't tuned 100%, but I'm still fairly happy with it. With ITB's and a stand alone you should be in nice shape. As for the renesis rotors there are issues running them in older engines. As far as I know there are slight differences in seal design and placement on the rotors that make fitting them in the older engines a problem. I think it can be done, but you'll have to do some more research on that one.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 06-15-2010, 09:09 AM   #8
infernosg
IT'S ALIVE!
infernosg's Avatar
So what constitutes a half bridge on a 4-port motor? I always assumed a half-bridge referred to bridging the primary ports on the 6-port motors.
Either way, I still don't have a motor to play with. The seller of this particular one flaked out (just never called me back) even though it's still being listed as for sale. His loss...
Old 06-15-2010, 03:08 PM   #9
You can search for the exact definition of the half-bridge, but it's basically half the length of a normal bridge; hence why you won't have to cut into the water jacket.
http://www.rotaryengineillustrated.c...e-port-12.html
Their J-port is everybody elses Bridge port.
Old 06-15-2010, 04:20 PM   #10
Buggy
I've been Wankeled!
Buggy's Avatar
On my engine I just did an ordinary bridge port on the secondary ports (the ones in the outside irons) and just a streetport on the primary ports (in the center iron). I didn't have to cut into any water jackets on mine, but it is just a 4 port.
Old 06-16-2010, 01:32 AM   #11
SLIDN2
SLIDN2's Avatar
I did the exact same thing normal bridgeport on the outer plates and a big street port in the inner one, also I ported the exhaust ports and pinned the engine just incase I wanna give it a nice NOS shot later on, remember rotarys love nitrous.
Old 06-16-2010, 06:19 AM   #12
Buggy
I've been Wankeled!
Buggy's Avatar
Ya, I completely forgot to mention that I played with the exhaust ports as well. I'm actually curious myself as to what my engine can do. I need to get it to a dyno and do some pulls. The weber still needs some tuning but it still pulls pretty nice. In 4th gear (which is all I've got) you can stomp on it at 60mph and it just pulls away untill you hit speeds that are relatively unsafe with 34 year old brake and suspension technology. The only thing I may change is to go with a different carb. The 48 IDF is a bit small. It feels like it's choking out at the higher RPMs. I was toying with the idea of a dual 40 IDF setup. Might make things interesting.
Old 06-15-2010, 08:08 PM   #13
NoDOHC
NoDOHC's Avatar
Hey Buggy, I am curious what you get on the dyno with your setup. That will be interesting to contrast the power band of that engine to the one that I posted earlier from mine. You probably have a naturally better intake, but I am mostly interrested in low end, torque curve, etc. Also, what do you get for fuel economy?
To the original poster: Go 4-port FTW! I was worried about losing low-end going from a 6-port to a 4 port, but the 4-port stomps the 6-port above 1800 rpm. Meaning that you get better grunt, even on the interstate in high gear. Idle is good and mileage doesn't suffer much (35mpg 6-port -> 30 mpg 4-port with NA 5-speed, 25 mpg 4-port with turbo 5-speed).
The 4-port is easy to work on (all kinds of space where the turbo is supposed to go), runs cooler (could be from the lower compression ratio) and is much simpler to tune.
The only thing I would do differently if I ever get a chance would be to use NA rotors instead of turbo ones. I don't know if the small weight savings and additional 3 point on the compression ratio makes it worth the expense for RX8 rotors or e-shaft.
Old 04-22-2011, 07:34 PM   #14
diabolical1
I have radioactive semen
i realize that this is a year old, but it's the first time i've read this thread, so forgive my late commentary and questions.
as i understand it, the Renesis rotors, on paper, should make slightly more power than the 9.4s and 9.7s given the same setup with only the rotors being different. all the hard facts support it - lighter, higher compression, bevels, etc.
however, most reports from people that have actually put them in older engines have them making the same power at best, and actually making less power in the majority of the time. i've read a couple of theories on why - some sort of make sense to me, some don't, which leads me to believe if anyone actually KNOWS why, they're not talking about it. my guess is greater heads than mine are still working on it.
no doubt some people are not regretful for using them, and make decent power, but with the trouble of the extra machining and balancing, it comes down to personal choice really. i suppose it still carries a coolness coefficient with it as well. however, it doesn't appear that more power has been validated.
as for timing issues with them, i don't know if you'd call it "issues" per se, but they appear to tolerate (even prefer) more aggressive ignition timing when being tuned.
more of an addition than a correction, but remember the Renesis rotors are beveled from the factory, so the intake timing for any older engine using them will be slightly different.
half bridge is when you bridge just a half of the engine - meaning, there's one bridgeport per rotor instead of two (full bridge). convention usually bridges the secondaries only, but i have heard of a handful of people that for whatever reason, bridged only the primaries.
Originally Posted by NoDOHC View Post
... but the 4-port stomps the 6-port above 1800 rpm. Meaning that you get better grunt, even on the interstate in high gear. Idle is good and mileage doesn't suffer much (35mpg 6-port -> 30 mpg 4-port with NA 5-speed, 25 mpg 4-port with turbo 5-speed).
this is going to sound way more confrontational than i mean it to be, but where are you getting this from? i'm MOSTLY interested in the parts i bolded, but i'd like to know for the sake of curiosity and/or possible learning, about everything you mentioned.
Old 06-16-2010, 01:29 AM   #15
SLIDN2
SLIDN2's Avatar
Just go with a TII engine with na rotors for high commpresion.
GSL-SE rotors are actually considered light and high compression.
