Old 04-16-2010, 10:13 PM   #1
streetpimp105
streetpimp105
streetpimp105 is on a distinguished road
brake lights and turn signals need help fast
ok did a motor swap in my 86 rx7 that has been sitting for 10 years and the main problem im having from driving it is the brake lights and turn signals. i have all running lights and everything but not brake lights when i hit the brake and i also dont have turn signals. all the fuses are good and there and i switched out both turn and headlight switches and i still dont know what to do please help i need this car running fast. thank you
streetpimp105 is offline   Reply With Quote
Old 04-17-2010, 03:59 PM   #2
rotaryguy481
rotaryguy481 is on a distinguished road
Well for the break lights check the break light switch under the dash has alil switch that is on the break peddle and the blinkers check the relay
rotaryguy481 is offline   Reply With Quote
Old 04-20-2010, 03:01 AM   #3
FC Zach
FC Zach's Avatar
This may sound dumb but it's just my 2 cents:
-Check to make sure that you have good connections at the bulb sockets (highly unlikely that all the said bulbs could have bad connections but nothing seems to surprise me anymore) It has happened to me.
-Not only check the connections but make sure the correct bulbs are in each socket. Again, highly unlikely but it's something to check. For example, I've seen single filament bulbs in dual filament sockets on peoples cars in the past.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 04-21-2010, 11:34 PM   #4
My5ABaby
My5ABaby's Avatar
IIRC the wiring under the dash that connects to the switches can get burned out. Check to make sure the wiring is good (you should be able to see it kinda by the steering column) and not have to take the dash off.
Community Service Manual
RotorWiki
Old 04-24-2010, 07:55 PM   #5
MazdaMike
S4 Owner
MazdaMike's Avatar
MazdaMike is on a distinguished road
Its also possible that the circuit for those items has burnt out on the circuit board of the CPU. But if you have no brake lights at all I would check the switch on the pedal first, check the bulbs and connections and then check the CPU.
1985 Mazda RX7 GSL 13B, Holley etc
1997 Mazda MX6 LS - DD lowered on 17s
MazdaMike is offline   Reply With Quote
1986 rx7, brake lights, turn signals
