Old 04-10-2010, 02:19 PM   #1
ZGN
Administrator
ZGN's Avatar
RX-7 ABS troubleshooting FD 1993
My ABS light is on, any helpfull tips to determine the cause of this malfunction other than the fuse?
Kevin
Old 04-10-2010, 06:10 PM   #2
93rx7r1
93rx7r1's Avatar
93rx7r1 is on a distinguished road
Have you recently done any work around the front hubs? The wheel speed sensors wires are very easy to break.
My FD3S Build Thread
2005 Subaru Impreza WRX (daily)
93rx7r1 is offline   Reply With Quote
Old 04-10-2010, 06:18 PM   #3
Did you do any brake bleeding?
Old 03-14-2018, 09:58 PM   #4
alavochin
alavochin is on a distinguished road
If I did some brake bleeding and my ABS failed after.. what could it be?
I was installing an engine brace that required I remove the ABS pump. Reinstalled the pump and bled the brakes. Could not get get a real hard pedal, so it would take a couple brakes pumps for stiff pedal. Since I could not figure it out, I took the car around the block to see how it brakes while driving. ABS light came on. Back in the garage, I realized that my big front brakes had 2 bleed valves and I was only bleeding one of them. Fixed my mistake, rock solid pedal, but now the ABS light will not turn off and ABS system is not functioning.
What do you think happened and how could I fix it?
alavochin is offline   Reply With Quote
Old 04-10-2010, 06:18 PM   #5
ZGN
Administrator
ZGN's Avatar
Not recently, the light has been on for 2 years+
Just swapped out the abs pump, old one was leaking slighly. About to jack up the car and bleed the brakes. I'll check the speed sensors also.
Kevin
Old 04-10-2010, 06:19 PM   #6
ZGN
Administrator
ZGN's Avatar
we posted about the same time,
Kevin
Old 04-10-2010, 09:49 PM   #7
BigIslandSevens
BigIslandSevens's Avatar
I have all the sensors if any of yours are bad. Let me know if you need them. Free because we have the same birthday.
Dave
Old 04-11-2010, 11:17 AM   #8
ZGN
Administrator
ZGN's Avatar
Thanks, none of the appear broken. Do they every just go bad? Any way to test?
Kevin
Old 04-11-2010, 05:54 PM   #9
BigIslandSevens
I'd have to check the manual on testing them. I would imagine a resistance reading is the standard.
I also have 2 ABS computers. a 93' and a 94' As wel as a 94 pump
Old 04-11-2010, 10:36 PM   #10
93rx7r1
93rx7r1's Avatar
Unplug the speed sensor and measure the resistance between the terminals on the speed sensor side of the plug. The resistance should be between .8-1.2 k-ohms
Old 04-12-2010, 12:02 AM   #11
ZGN
Administrator
ZGN's Avatar
Thanks, I'll test them later today and also reseat the ABS computer connections!
Kevin
Old 04-25-2010, 06:57 PM   #12
Lilfreddie
Lilfreddie is on a distinguished road
Factory test equipment
Whats up! I have the factory ABS test equipment that plugs where the ABS ECU goes. If you need it let me know.
Lilfreddie is offline   Reply With Quote
Old 04-26-2010, 07:56 AM   #13
ZGN
Administrator
ZGN's Avatar
Yo man, have not heard from you in a while hows it going? ABS is on hold for now... blew my motor at DGRR 0 PSI on front rotor and 58 on all the faces on rear. Almost have the motor out. Just one stuck exhaust bolt to remove and it's comming out!
Kevin
Old 05-03-2010, 09:30 AM   #14
ZGN
Administrator
ZGN's Avatar
Thanks for the info. As soon as I get my FD back on the road again I'll continue to troubleshoot this issue and should have it resolved!
Kevin
rx-7 abs
