Old 03-20-2008, 04:40 PM   #1
93ONIGIRI
93ONIGIRI's Avatar
93ONIGIRI is on a distinguished road
93 ONIGIRI build
immigrating from okinawa and working in the rotary biz since 1995, i eventually purchased a 1993 base model FD3S (auto)... yeah. don't ask me why i ended up getting an auto FD, but my future posts will provide useful information.
09/11/04: 75k (9k on rebuild) full stock, except for the after market stereo system.
Last edited by 93ONIGIRI; 07-04-2008 at 12:39 PM. Reason: i had to set up a new photobucket account.
93ONIGIRI is offline   Reply With Quote
Old 03-21-2008, 04:27 AM   #2
blwnrtr93
blwnrtr93's Avatar
blwnrtr93 is on a distinguished road
That's an awful big box for a single 10" sub (?) But then again I'm just jealous.
1993 BB RX-7
2005 Black Mazda 6i
1991 Primer Celica GT
1968 Camo Chevy P/U
Garfinkle's Airpump Idler Pulley: Keep the stock contact patch on your water pump w/o running Airpump!
blwnrtr93 is offline   Reply With Quote
Old 03-21-2008, 09:56 AM   #3
93ONIGIRI
93ONIGIRI's Avatar
actually its an 8" sub. the car came with the aftermarket stereo system, which i've pulled out. i will most more progress pics shortly...
Old 03-21-2008, 09:33 AM   #4
VERY nice - I hope when I'm ready to get in the FD scene there are still clean ones like that available!
Old 03-22-2008, 11:34 PM   #5
93ONIGIRI
93ONIGIRI's Avatar
09/21/2004-12/27/04: 75k-77k
i started to replace parts that needed immediate attention, which the previous owner ignored to repair...
*AC BELT, DOOR LATCH ASSEMBLY, V BELT, THERMO WAX VALVE, FRONT/REAR BRAKE PADS, FRONT REAR BRAKE ROTORS, BRAKE LINES, O2 SENSOR, OIL PAN, OIL PAN GASKET, and HOSE RETURN LINE.
Circus Brake Pads (street)
Brembo Drill Slotted Rotors
Stainless Steel Brake Lines
Last edited by 93ONIGIRI; 07-04-2008 at 01:12 PM. Reason: i had to set up a new photobucket account.
Old 03-23-2008, 12:05 AM   #6
93ONIGIRI
93ONIGIRI's Avatar
08/22/2005: 78K (TRANNY SWAP)
After this experience, I highly recommend that if you plan to purchase an FD, definitely pick up a Manual Transmission. The cost for doing the tranny swap varies, which the following indicates my route:
USED PARTS:
MANUAL DIFFERENTIAL
MANUAL DRIVESHAFT
MANUAL TRANSMISSION
MANUAL STARTER
CLUTCH PEDAL
MANUAL ECU
TOTAL USED PARTS: $1,283.04
NEW PARTS:
CLUTCH PIPE (FD01-41-360A) $8.19
CLUCH PIPE (FD01-45-510D) $8.19
HOLDER (FD03-41-370) $6.63
HOLDER (FD00-41-370) $5.94
CLIP (0136-43-635) $0.94 (need 2)
PAD (FB01-64-495) $1.50
INSULATOR (FD01-64-495) $39.94
CLUTCH MASTER (FD01-41-990B) $88.88
CLUTCH SLAVE (FD01-41-920) $76.25
CLUTCH RELEASE FORK (N315-16-520B) $77.38
EXTENSION HOUSING SEAL (R501-17-335A) $13.94
OIL SEAL (H501-17-103) $3.13
SPINDLE (R503-17-550) $40.69
SHIFTER BUSHING (0398-17-462A) $3.75
MANUAL WIRE HARNESS (N3A1-18-05ZG) $700.00
TRANNY/STARTER BOLTS $35.55
CLUTCH RELASE BEARING (N315-16-510) $66.88
TOTAL OEM PARTS: $1178.72
EXEDY TWIN PLATE CLUTCH $1355.00
B&M SHORT SHIFTER $129.02
MOMO SHIFT KNOB $84.00
STAINLESS STEEL CLUTCH LINE $38.00
TOTAL AFTERMARKET PARTS: $1606.02
GRAND TOTAL: $4067.78
Last edited by 93ONIGIRI; 07-04-2008 at 01:53 PM. Reason: i had to set up a new photobucket account.
Old 03-24-2008, 03:52 PM   #7
Jarred
With eyes of a hunter...
Jarred's Avatar
Jarred is on a distinguished road
Lookin good so far! I'll be watching this one.
Jarred is offline   Reply With Quote
Old 04-01-2008, 03:13 PM   #8
Nutsid
Temporarily insane.
Nutsid's Avatar
Count me in for updates.
Kindle
Nook
Old 04-13-2008, 09:51 PM   #9
93ONIGIRI
93ONIGIRI's Avatar
08/22/2005: 78K (FUEL FILTER, DIFFERENTIAL MOUNTS)
As I was doing the tranny swap, it was a good time to replace the fuel filter, which needed replacement after hard morning start ups.
RP Fuel Filter
This is probably one of the worst locations for replacing the fuel filter, which I also decided to replace the differential mounts.
Circus Differential Mounts
Old 04-20-2008, 10:39 AM   #10
dcrasta
dcrasta's Avatar
dcrasta is on a distinguished road
Nice car! Watching closely (you're thread inspired me to get started on my mounts'!)
dcrasta is offline   Reply With Quote
Old 04-24-2008, 08:31 PM   #11
93ONIGIRI
93ONIGIRI's Avatar
08/22/2005: 78K (Fuel Pump)
After installing a new fuel filter, it was a good time to install a new fuel pump and fuel pressure regulator.
Circus Walbro Fuel Pump
Rx7 Hyperrev Magazine coverage featuring my supervisor...Kazushi Shinjou
Nismo RB26 Fuel Pressure Regulator
Old 07-06-2008, 11:12 AM   #12
93ONIGIRI
93ONIGIRI's Avatar
08/22/2005: 78K (Suspension)
After 12 years of use on the original suspension, it was time to swap out and replace them with new suspension reinforcements.
PCR Mazikayo spec Dampers ($5k)
Cusco Front Strut Bar
99spec Rear Sway Bar
Old 01-19-2009, 11:09 PM   #13
93ONIGIRI
93ONIGIRI's Avatar
07/02/2006: 78K (Cooling)
At this time, all necessary cooling upgrades were add, which modifying a poorly designed intercooler was a must. The original design blocks off the air flow for the radiator, which in Japan a common mod would be to cut a core out (this does not affect the performance of the FMIC).
Greddy 2row FMIC (modified by Circus)
Griffin Radiator
Samco Radiator Hose
AST
Tial 50mm BOV
Hose Techniques Silicon Hoses
Old 01-19-2009, 11:16 PM   #14
93ONIGIRI
93ONIGIRI's Avatar
07/02/2006: 78K (Wires)
This is probably one of the worst mods that I have done. Definitely drains if you don't start up within a week, yet convenient fit within its original space.
Odyssey Mini Battery and Bracket
Nology Hot Wires
Sun Auto Hot Earth
Mazdaspeed NGK 10.5
Old 01-19-2009, 11:23 PM   #15
93ONIGIRI
93ONIGIRI's Avatar
07/02/2006: 78K (Interior)
Probably a must out all meter readings...
Integral Knock Meter
Defi 52 Gauges (Turbo, Fuel Pressure, Water Temperature)
Defi Link
OEM efini Bathurst Momo Steering Wheel
