| Ludwig Motorsports www.ludwigmotorsports.com (IN/KY) Full service; rotary engine builds, swaps, fabrication, etc. |
Rotary Masochist
New M&W CDI for 3-channel ECUs
Just got confirmation that M&W has a new box, which is labeled the Pro 14R V2. The V2 is specifically designed for 3-channel ECUs like the PFC, Haltech E6K/X and Mircotech boxes. This box will do true 4 channel, direct-fire output with only the 3 channel, wastespark input. I don't have the specifics on how it operates but I'm guessing it references T1 and knows the firing order after will then be L2, T2, L1. So, with the V2 box, leading will not fire in wastespark as they do when the regular Pro 14R is installed on a 3-channel ECU, but in direct-fire, spark per revolution mode.
Not sure there is a real benefit to running direct-fire v. wastespark with CDI. It's not like an inductive system where duty cycle becomes a concern at high revs. It would obviously allow the leading coils to operate at half the duty and maybe help with any potential heat issues on extended duty circuit applications. Price will be the same as the regular 14R, but my distributor is probably not going to stock them. If that's the case they'll need to come from Australia and you're probably looking at a 3-4 week lead time.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
