11-30-2009, 09:16 PM | #1 |
Aftermarket Fuel Rails?
Hey can anyone give me some direction on where to get some good aftermarket fuel rails for a decent price.....
Any help would be great thanks If anyone knows of a good place to pick up -AN fittings for great price let me know that too!
12-01-2009, 12:30 AM | #2 |
I don't know about aftermarket pre-manufactured fuel rails, I know you can buy fuel rail and a special drill bit and make your own.
The stock s5 fuel rail is pretty good. Be careful of Stainless steel lines. If properly installed, they are Ok, but they have a nasty tendency to spring leaks at very inopportune times.
12-01-2009, 10:56 AM | #3 |
I have an S4 I know there are some aftermarket fuel rails you can buy I could buy aluminum and drill injector holes but I dont have anything to tap to put the fittings in... Im going -AN....
12-01-2009, 11:28 AM | #4 |
I usually buy the bungs and TIG them on. Makes for tighter fitting fittings. Any machine shop will be able to tap them. I would be worried about drilling holes for injectors though. Without a proper bit/polishing of the bore, you're likely to tear and o-ring or have the potnetial for leaks
12-01-2009, 12:08 PM | #5 |
Rotary Masochist
http://kgparts.com/index.php?page=kgfuel
http://www.skernracing.com/fuelrails.html I've made my own and used a few different aftermarket rails. If you haven't made them before just buy them pre-made and save yourself some headaches. Summit and Jegs are hard to beat on their -AN prices. Their house brands are less expensive but I have had issues with the Summit brand leaking. I'll usually pay the markup and stick with Earl's because I know I'm getting a quality part. With the S4/5 you can have the Bosch injectors setup with a pintle cap that allows them to fit in the stock manifold without the need for sleeves or a wad of o-rings to get them to seal correctly. Marren sells these injectors as their "Pro-Import" injectors at a serious markup. If you have a competent injection shop close by you can take a regular "domestic" Bosch EV1 injector and have the pintle cap changed to replicate the Denso injector for a stock fit with the stock injector grommets.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI Last edited by C. Ludwig; 12-01-2009 at 12:11 PM.. |
12-03-2009, 12:00 AM | #6 |
.drives like MrMagoo!
Kg rails..and Keith can make any Modifications you need to accomodate you.
I am in Canada and I deal with this Gentleman beacuse he responds quick,Knows his stuff,and his prices are good and reflect quality parts,. His shipping/Turn around time is Real fast..Five days is VERY good for US/Canada shipping. |
12-03-2009, 02:39 AM | #7 |
If you decide to make your own fuel rail, make sure you use the appropriate size ream bit. Also, radius the leading edge of the hole to allow the o-ring to squeeze in. Cratex bits work great for this, as well as the polishing Titanium mentioned.
12-11-2009, 10:26 PM | #8 |
can you not just get an fitting adaptors for the Stock S4 turbo rails? Something like 12x1.25-to-AN size and then use fittings and lines?
IE: http://www.pegasusautoracing.com/pro...asp?RecID=5936
