Old 11-30-2009, 02:48 AM   #1
Megasquirt Advice and discussion.
I have been considering building a megasquirt setup for my car. Considering the alternatives, such as used Haltech units, or RTEK, which ends up at around $750 after all is said and done, and any other alternatives such as a blow-through carb setup for my car, I have arrived at the conclusion that an MS standalone would fit me very well.
After reading over Aaron Cake's guide: http://www.aaroncake.net/rx-7/megasquirt/index.asp
I have priced out all the major components that I will need at roughly $500, plus all the misc stuff like solder, connectors, etc, so figure $700 for the budget...
This price includes the MS 1 V3 kit, An LC-1 wideband kit, and some mod chips and misc items such as fan controllers, boost controller kits, wiring harness, etc.
I have seen used standalones such as Haltec and Microtec sell on the forums for a similar price, most with a complete harness and sensors included. While I would like to build my own setup, I thought that I might need to weigh in the advantages of other options.
As far a tuning, I believe that I can get a rough map going, but in order to REALLY tune the car, I will need to seek help of a pro. How much of this stuff can I get done myself if I really study it, and spend time adjusting the maps? I don't seem to have many tuning options in my area other than Banzai Racing and Chris Ludwig in Indiana, both of which will require me to drive the car over there in order to get it tuned, how scared should I be at this point?
Opinions, experiences, suggestions, and all are welcome, the stock setup on my TII has aged well, and is in need of replacement sometime soon.
Max.
Old 11-30-2009, 09:54 AM   #2
dregg100
go with anything but a ms. by far the worst standalone i have ever used.
'93 SSM Touring-S475...
'87 Tii-LS1/T56
Old 11-30-2009, 10:29 AM   #3
RotaryProphet
If you know what you're doing, the Megasquirt is fantastic. Cost to feature ratio is unparalleled, and I've put a hundred thousand miles on my DD while it's been Megasquirt powered. To top it off, it has OEM drivability, never surging or bogging, and you can reach in through the window on the coldest day of the year, turn the key for a half second, and it's running. The hardware does what the hardware does, it's up to you to tune it, though.
As for tuning, there are a few ways to go about it. The easiest is to take it to someone who specializes in it. I'm near Cincinnati, and I have an engine dyno cell setup pretty much just for doing Megasquirt installs that I build and wire, but I'd be more than happy to help you out for pretty cheap; I try to cut forum members price breaks where I can.
Secondly, with a wideband you can run a datalog while driving (assuming you've roughed out the tune to where you can drive it), then import that into excel or openoffice, and go back through and look at the recorded AF ratios at given RPM and MAP points, then do the math to figure out what the cell -should- be at to get your desired AF ratio. It's far from perfect, but I've tuned cars that way that ended up working very well, and without an engine dyno, it's one of the only ways to really tune the regular city driving areas of the map.
The last method would be to recruit a friend to drive around while you sit in the passenger seat with a laptop, and adjust as you see fit. Before I had my dyno, I used a combination of logging and shotgun tuning to get a reasonably good tune, but it is time consuming.
Old 11-30-2009, 05:41 PM   #4
You seem to imply that only MS can do this...
The fact of the matter is that almost any competent aftermarket EMS can do this, and it's not limited to MS.
My Haltech E8 has no problem doing any of the above that you have mentioned unless one of it's sensors dies - I recently had a TPS (*#%& GM sensors) fail on me.
Anyone that has driven my car also comments how "OEM" it feels and drives.
Bottom line...the EMS if only as effective as the tune or how competent the tuner is.
Given the best EMS like a MoTeC in the hands of someone who doesn't know what they are doing, and it's...useless.
Old 11-30-2009, 11:20 PM   #5
RotaryProphet
Actually, that's more or less exactly what I was trying to say. That the MS is directly on par with any other EMS system I've seen as far as in-use functionality.
It's just, every once in a while, you have to build a circuit to do some goofy thing you want to do; and even that isn't a big deal if you're handy with a soldering iron, and know what you're doing.
The Megasquirt is the option for people who really really know what they're doing, or want to learn. The upside is, it's damned cheap, and works just as well. The downside is, it's more work, at least the first time.
I'm actually curious about how poor a reception the MS gets in a lot of car circles; even those who are thoroughly DIY with their engines are terrified at the thought of doing the same to their ECU.
Old 12-01-2009, 06:41 AM   #6
No warranty.
No service.
No tech support, unless you count on other enthusiasts who are trying to do the same thing, and you're counting on them to know more than you do.
Was that a serious question?
Old 12-01-2009, 10:17 AM   #7
RotaryProphet
No warranty.
No service.
Do you have warranty and tech support on the motor you build, or the turbo you port the wastegate on?
I suppose there are different levels; people who build things, and people who buy and install things. You seem to be implying you're the latter; and that's fine. But if that's the case, you expect to pay more for that luxury. There are those of us out there who prefer to save the money, and do it ourselves. And given the fact that I can crank out a few Megasquirt ECUs for less than the price of most anything else out there, and that once built, nothing is ever likely to go bad (speaking as an embedded systems programmer on similar industrial solid state electronics), I'm not too concerned about a warranty, and as I have Google, I'm not to worried about tech support.
There are plenty of people out there who, even given the circumstances and available tools & materials, would never fabricate a part for their car. The Megasquirt is not for those people.
On a completely separate note, DIYAutoTune has released a kit designed to mount a Megasquirt into a stock S4 or S5 ECU case, and use the stock wiring harness... pretty much a PnP setup. I haven't played with one yet (mostly, I like replacing the stock harness with my own, much smaller and neater one), but it seems like there might be a market for these pre-built.
Old 11-30-2009, 11:39 AM   #8
i am going to be converting from distributor to CAS w/ ms controlled spark (already running fuel) over the winter. The ITBs and anything with vacuum control dont get along...
Old 11-30-2009, 03:48 PM   #9
So, what if I were to fully set up my car with the MS, and then trailer it over there to get it tuned?
Old 11-30-2009, 11:26 PM   #10
RotaryProphet
Better option would be, since I have an engine dyno, not a chassis dyno, just bring the engine, with complete intake and whatnot. The dyno cell has it's own water supply into the water pump, and it's own fuel system that hooks up to the rails. It also has a water-air intercooler to be used to control IAT.
If you're interested in tuning it on the dyno, give me a PM, and we'll talk about it.
Old 11-30-2009, 04:40 PM   #11
I love my Microtech...There is a reason some of Australia's fastest rotaries run Microtech
Old 11-30-2009, 05:04 PM   #12
Motec all the way baby. Functionality, configurabiltiy, adjustability is unparelleled.... not to mention the best support I have ever had the pleasure of dealing with.
You have problems with the MS, where do you turn?
Old 11-30-2009, 05:21 PM   #13
Microtech's Tech Support is good but kinda slow...But half the price of Motec too
Old 11-30-2009, 05:26 PM   #14
Well, if I had $8,000 for your setup, T, I would duplicate it minus the sequentials.
Old 11-30-2009, 11:26 PM   #15
Well, I see the only problem with the MS install is that I want to have my car ready for DGRR-10 this spring, so if I can save up the cash, install the hardware, and get it tuned in time, then I will be going with this setup. Otherwise, i will need to put it off and get an RTEK 1.5 chip instead.
