| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
s4 t2 rummage sale. cheap
bac and acv valves - $5 each
n332 ecu - $20 a/c compressor - $20 p/s pump - $20 p/s cooler - $10 p/s & a/c bracket - $10 p/s & a/c tensioners - $5 each omp, no lines - $10 oil injectors - $10 UIM - $20 - pending power steering rack - $30 logicon (working, don't know the age) - $20 k&n drop-in filter - $10 random a/c and p/s lines - ask and make offer. i should have what you need. |
Clean S4 Nutswinger
What kind of shape is the K&N drop-in filter in? Where are you located?
located in houston texas. drop-in is in good condition. doesn't have a whole lot of miles on it.
UPDATES
acv valve - $5 n332 ecu - $20 a/c compressor - $20 p/s pump - $20 p/s cooler - $10 p/s & a/c bracket - $10 p/s & a/c tensioners - $5 each omp, no lines - $10 oil injectors - $10 UIM - $20 - pending power steering rack - $30 logicon (working, don't know the age) - $20 k&n drop-in filter - $10 random a/c and p/s lines - ask and make offer. i should have what you need. |
Found the cleaner and oil for the filter. $25 for the whole package shipped.
a/c compressor pending and k&n sold.
acv valve - $5
n332 ecu - $20 p/s pump - $20 p/s cooler - $10 p/s & a/c bracket - $10 p/s & a/c tensioners - $5 each omp, no lines - $10 oil injectors - $10 UIM - $20 - pending power steering rack - $30 logicon (working, don't know the age) - $20 random a/c and p/s lines - ask and make offer. i should have what you need.
acv valve - $5
n332 ecu - $20 p/s pump - $20 p/s cooler - $10 p/s & a/c bracket - $10 p/s & a/c tensioners - $5 each omp, no lines - $10 oil injectors - $10 UIM - $20 - pending power steering rack - $30 random a/c and p/s lines - ask and make offer. i should have what you need. i believe that i also have the a/c condenser and the lines to it. pretty sure i also have the dryer and the lines. i will get some pics up of the random lines that i have. logicon spoken for.
