rewire fogs, headlight motors, and high beams
I am currently replacing all the bulbs in my car with HID's and wanted to change some stuff around. This is all on a s5 vert btw
first off my highbeams haven't worked since I bought the car, if I pull on the light stalk with the headlights off it will flash them but only the low beams, however with the lights on I pull the stalk and nothing happens. Do the high beams use a seperate fuse or a relay or is this a common problem that is fixed else where? The bulbs are brand new so that's not the issue Secondly I want to wire it so I can turn my fog lights on without having to turn on my headlights even if I have to turn on my parking lights that's ok just want fogs without headlights...any wiring suggestions I would appreciate it. Lastly and not highly important but I want to know if its possible to rewire the headlight switch where when I turn the headlights on the headlight motor switch will still allow me to flip them down and direct them through the ftp's. Thanks in advance for all the help. |
Rep Power: 22 ![]() |
Icemark used to build switches that could do exactly what you want. I was actually about to order one when he unfortunately passed away.
Does anyone know if he passed his knowledge to anyone? I would like to know!! I know funkspectrum has his old 10thAE. Maybe he can help.
#3 | |
Louvers!
For the fogs you'll need to find a source of constant 12+V and put it on the fog light switch's Red/Black wire. The pic I attached is from the '91 wiring diagram.
Found this in one of Icemark's post a while back for the headlight switch: Quote:
88 GXL N/A -- Maybe I should've kept the exhaust diffusers... Last edited by Howru; 08-05-2009 at 01:22 PM. Reason: Almost forgot the attachment. |
Cool thanks for the heads up guess I will have to find the diode in that switch
