Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 07-31-2009, 06:20 PM   #1
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
RotaryDiagnostics is on a distinguished road
What is it?
Bryan,
Can you tell me what I have here? Picked up this turbocharger from someone on that other forum. It definitely is an S5, based on the N370 stamp on the compressor section and the dual wastegate ports on turbine side. However, the connection points for the oil and coolant pipes are not in the correct position. It appears to me that the unit has been disassembled and reassembled incorrectly so that the central, connecting section is not in the correct rotational position. What do you think?
The first image is of the S5 unit on my car. The rest of the images are of the recently purchased turbo. Notice the difference in the wastegate actuator rod. Strange.
RotaryDiagnostics is offline   Reply With Quote
Old 08-01-2009, 07:57 AM   #2
The wastegate rod was straightened and shortened. I have seen it before. Also it looks, like you said, to be clocked differently.
Maybe it was in a FB or something?
Old 08-01-2009, 02:09 PM   #3
RotaryDiagnostics
Yeah, don't know about the wastegate rod. It actually looks longer than the 'bent" rod on my turbo.
Contacted the seller today and he said that he had disassembled it to "clean" it and must have reassembled it incorrectly. He never installed it on an engine.
Old 12-09-2009, 12:39 AM   #4
Bryan@BNR
Bryan@BNR is on a distinguished road
Yeah that turbo had a S4 wastegate actuator on a S5 turbo. They are different . I fixed that problem with the correct part .
Bryan@BNR is offline   Reply With Quote
