			 Reliable Source
				Rep Power: 18 ![]()  |
				cranks and wont start or when starts wont stay running
			Okay I have an S4 NA with an 89 NA motor in it and I've gotten it to start earlier in the week and I had it idling, then the other day I got it idling for about 10 minutes then it stalls and I haven't been able to restart it since.
	I know it flooded because the oil smells like gas and I've already been through a set of plugs, I don't want to buy a 3rd set for going 0 miles. so I've been cleaning and drying them up and now the car will only start when I put copious amounts of starter fluid in at the throttle body and then it seems to die after it runs out of starter fluid. so now your thinking its a fuel problem but I am getting fuel because it floods, the injectors are fine and they have been rebalanced and cleaned by a very reputable professional. I am using S5 fuel rails and FPR. the coils are getting power and are within spec the TPS is properly adjusted plug wires resistance is 9.08Kohms for the Leading side and trailing side are 6.75kohm and 14.45kohm (same wires on the previous motor and never had a problem) the AFM is within resistance specs and flapper moves freely. CAS is within spec and has not been removed from the motor, to avoid errors from re-stabbing it battery is new and fine and I get a 2 volt drop during cranking so the lowest it gets is around 10-11volts during cranking and the starter solenoid is new. I brush off the plugs and clean them out with carb cleaner, let them sit and it wants to start but doesn't. None of this makes any sense since I had it idling and starting fine only a couple days ago and no changes have been made. I haven't changed the oil yet since I want to get it to start before I change it just in case it floods again, and it uses premix so I dont have to worry about it injecting gasoline diluted oil in the housing. I'm running out of ideas, after all I heard it start and run for a while and without changing anything it just wont start... help?
			 Reliable Source
			so I put about 2 tablespoons (I have a "flavor injector" for a needle) of premix oil in each rotor housing and gave the plugs a rub and put some starting fluid in on the throttle body and it fired right up nearly then smoked a bunch of oil out and I drove around the block a few times and it ran like a fucking champ and then I pull in my driveway and let it idle for a while the water temp got up to 150 degrees and stalls and I cant get it to restart and continue running by even using the same methods to get it started.
	BUT I was able to get it started, barely, and then it ran like ass, ( pulling the plugs, cleaning them, adding more oil in the chamber, starting fluid ) I had to give it a lot of throttle for it even stay running and it didn't do that very long, it sounded like it was getting choked. the fuel filter is new, I get even pulses when de-flooding. it sounds like it wants to start better with the massive mounts of oil put in the chamber.  |
		#4 | |
			 S4 INTO S5 Turbo II OWNER
				Rep Power: 17 ![]()  |
 1) your using an s5 engine on an s4 ecu. 2) s5 injectors have diff resistance then s4's (back to #1 problem) 3) compression ratio in s5 engine is diff then s4 (s4=146hp s5=160hp) (back to #1 problem) solution to try... take s4 injectors and put into s5 engine try that. if that doesnt work then you need to wire it for s5 ecu. or swap back in an s4 engine.  |
				Rep Power: 10 ![]()  |
			Check your thermo-sensor in the back of the waterpump housing.  Then check the pins at the ECU and make sure the resistance is the same at the sensor and the ecu
			![]() Oh, comp ratios have nothing to do with compression in the context of this discussion
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
