frustrated!
Rep Power: 17 ![]() |
Brazing rear iron dowel on S4 13BT??
I have heard of earlier tuners doing it before the 13REW came out.
Anyone here done it OR seen it?
Same pig, new soul
No but i'm interested in hearing more
what would this do?
prevent cracking the dowel landing.
Slow
I'm sure you'd have better luck picking up a S5 or REW rear iron.
frustrated!
just ordered a brand new S4 rear iron that comes from Mazda with the updated FAT casting.
Same pig, new soul
How do you know it does? I need more info.
frustrated!
Mazdatrix told me so.
They stated every new S4 rear iron comes with the updated casting seen on 13REW's. They also recommended I replace my rear rotor housing becasue they state every rear iron break they have seen causes the rear rotor housing dowel hole to "oval". I asked for some measurement tolerences from them since the FSM doesn't specify. I am awaiting a response. Since I have a hair line crack and I pushed 17 psi once on low compression rotors when my WG went tits up(15.4 psi is my normal boost), I am skeptical that my rotor housing is "stretched". I guess I will see once I pull it apart.
Same pig, new soul
#9 |
crash auto?fix auto
Yep at this point, all of the OEM stock is the later casting/thicker casting babies.
Interesting point about the ovalling of the dowel land in the housing, never thought about that but it seems to make sense - check it for sure though ![]() Oh and have fun with the OEM iron's ports They're usually rougher then jason statham's stuble.
#10 | |
frustrated!
Same pig, new soul
#11 | |
Clean S4 Nutswinger
You could probably pick up a junk iron or 2 for fairly cheap to learn on.
