| Carburetors and Carb Tuning.. All info about old school carb set ups.. |
Turboed carbed FC
Just wandering. i just got my hand on a bridgeported carbed fc. thinkin i might want to turbo it. its an s5. I know people have done it.
does anyone know of any build threads. or anyone who has done it with good luck.
1988 Fc Vert. Super Stock 1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
#2 | |
Custom User Title
I'm in the process. It's not that popular among FC owners, but FB guys do blow-through quite often. What carb does it have now?
shookmotorsports.com
Which weber are running??
It's pretty easy to setup them up for blowthrough. I used to have first gen that set up a Weber 48 DCO to run blowthrough. The problem that you are going to face is getting a proper sized turbo to work with that bridge port at the pressure levels that a two barrel can work with. |
crash auto?fix auto
Just build a box for the carb
![]() Tonnes of info out there on blow through setups, but if you want real guru information on that - you won't find (much) of it on import forums - if it doesn't have fuel injectors most of them don't know what to do! ![]() Gotta find old school minds for that information. |
ORD - Old Rotary Dude
A Holley setup would be the easiest, but the IDA would turn the most juice. The problem with running a turbo IDA is the float. No one sells a float that can handle more than about 5-7 psi.
Carb bonnets are readily available for the Holleys, not to mention all of the internals can be easily changed to accomodate a blow through setup. |
[QUOTE=nolimitind;80232]A Holley setup would be the easiest, but the IDA would turn the most juice. The problem with running a turbo IDA is the float. No one sells a float that can handle more than about 5-7 psi.
QUOTE] an IDA will make good power when used in a blow through application and i sell solid floats for the IDA, so there is no limit to how much boost you can run.. the accelerator pump circut works fine too.
![]() ![]() ![]() rotaryshack.com |
#7 | |
Custom User Title
I hear the accelerator pump is also problematic for blow-through IDAs.
Even easier than a Holley would be an OER, or even a DCOE with the later-style plastic floats. I'm going to be using the latter. RotaryShack will sell you a carb hat for the DCOE or OER, but I'm cheap so I'll probably make my own.
Well there ya go! Leave it to tha Shack to come through with the solid floats! I searched for years (not lately) and couldn't find even a European, Italian, Chinese, or Japanese supplier for these. I may have to the build that I wanted to do about 5 years ago now.
Another thumbs up for tha Shack! Todd B. |
#9 | |
ive done tons of carb blow through setups for over 18 years.. if you have any questions please ask. to get some ideas click the link http://www.rotaryshack.com/ourcars.html here is a video of how the blow through cars run ![]() http://www.youtube.com/watch?v=fPj2-afWOg0
#10 |
