| 1st Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed. |
Lots of 85 gsl-se parts. engine trans ecu interior switches wiring etc...
All of these parts are off of an 85 gsl-se. If its not listed on here i dont have it for sale If your interested in more than one thing let me know ill work u a deal. Or you could make my day ill load it all on a pallet and u can get all of it.
I have pretty much everything u need to get a gsl-se engine running in your car. All prices are without shipping. Interior parts: Hazard and headlight "popup" switch 10$ Rear defrost and wiper switch 10$ Logicon 20$ Instrument dimmer controll 5$ cruise controll switch 5$ Cigarette lighter 5$ light/wiper/cruise/turn signal switch (a couple tabs broken in the middle) 5$ Rearview mirror w dome and map light (Mirroring coming off of glass on part of the edge) 10$ E-brake handle (red) 5$ A/C evap box with evap core 15$ Clutch and brake pedal assy w/swithes 15$ Electrical: Atmospheric pressure sensor 5$ Vane airflow meter X2 15$ each dash/interior harness w fuse blocks 30$ Engine harness (fair condition) 20$ BAC 10$ ECU 20$ Fuel pump 20$ Coil 5$ Exterior: Power mirrors 20$ Drivetrain suspension etc: Newish clutch (lots of life left) PP and disc 20$ Brake booster 15$ PS pump with solenoid 15$ GSL-SE Oil cooler 40$ Transmission 50$ swaybar 15$ Speedo cable 10$ TB Plenum and uim 20$ Air box 10$ Ps pump 10$ Alternator 15$ Trans X member 10$ TB ductsX2 10$each Engine: Car had 150k on it started and ran fine. Has Intake manifolds TB fuel rails and injectors. also has water pump and flywheel. 300$ |
less roof, more turbo...
PM sent
pm replied
#4 | |
Rep Power: 21 ![]() |
680cc Injectors available by themselves?
sure...
#6 | |
Stereo volume knob?
Im also going to have the engine and trans currently in the car for sale soon. With all the sensors ecu fuel pump and everything else to get the se motor running in a cae. Everything minus the oil pan.
Ill put an updated list of whats still for sale this evening. |
might also want to add where your located
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) |
#9 |
Parts are all gone. thanks guys
