Engine Mounted Oil Catch Tank
Hey guys,
I'm trying to gauge interest on a potential GB for my engine mounted oil catch tank. This would be for the single turbo guys only. I need to add up the cost but I thinking it will be in the $150-$200 range depending on number of units. The capacity of the tank is 1.1 Litres. Note, I currently have 1/4" vent lines on there, but will most likely got to 3/8" or 1/2". Interest List: 1. CYD 2. John Magnuson 3. Scrubolio 4. 5. 6. 7. Last edited by afgmoto1978; 11-06-2008 at 07:26 PM. |
More pictures of current setup with everything installed.
This is of an older design that is currently on jkstill car and so far is very impressed with the performance. http://www.rx7club.com/showthread.php?t=729453&page=2 Note the back mounting tab, if you no longer have the mounting point on the engine rats nest cage I will need to do something different for you. |
#3 | |
After running 5 autox days and getting about halfway through a track day, the catch can was about 3/4 full. Much less oil loss than before the vents and can were added. Emptying it is a piece of cake: jack the car up high enough to reach the hose coming through the undertray, put a bottle under it and open the petcock. Or just drive it up ramps. I drive it up on my trailer ramps to empty it. |
Viable Fossil
I'm still on stock twins, but nice work.
I have a friend running a single who runs a tank for a 2 cycle oil source with his OMP. Seems like he's had issues with finding a suitable tank and location. Wondering out-loud if this could/would be option.
Jim VR R1 FD |
Yeah I can make it into a pre-mix tank, actually I was thinking of that as well earlier today.
I can make something special for him to maximize capacity as well, it will just be a bitch to install. |
I'd be very interested in this if you could do it. However, I've removed the rats nest and everything associated with it since I went single turbo---would need something other than the mounting tab that you have on the current prototype.
Interest List:
1. CYD 2. John Magnuson 3. Scrubolio 4. Trout2 5. 6. 7. |
Beautiful piece man. Why won't this work with the stock twins?
Proud owner of a base 1993 Montego Blue FD. PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings Many thanks to Dave at KDR for sparking my rotor addiction. |
#9 |
Viable Fossil
Because the vacuum chamber for the stock twin's sequential system normally occupies that space.
Jim VR R1 FD |
#10 |
Ah thanks, might be worth relocating the vacuum chamber for this piece very clean looking.
#11 |
Already covered, I did the same with my setup. You just need to drill and tap the metal carrier bracket above the power steering pump tank.
#12 |
That's an easy fix!
So when can we see a larger capacity version with an oil cap for a 2-stroke tank? Ready to write a check |
#13 |
#14 |
Oooh two stroke reservoir. That sounds good. How do you see the oil level and how do you drain it?
#15 |
Sight line and ball valve at the bottom of the tank with a outlet line that long enough to go past the power plan frame. See photos on first page.
Interest List: 1. CYD 2. John Magnuson 3. Scrubolio 4. Trout2 5. GoRacer 6. 7. |
