Old 11-03-2008, 04:31 PM   #1
Red Dragon
Rotary Enthusiast
Red Dragon's Avatar
Red Dragon is on a distinguished road
Emission Removal
Hey guys I was wondering if there are any writeups on Emission removals. I hoping to start this soon.
N/A 1987 RX7 (restoration coming along)
Red Dragon is offline   Reply With Quote
Old 11-03-2008, 04:33 PM   #2
its pretty straight forward. I did mine about a month ago, but i have no write up of it or pictures.
BUT i can give you a low-down on what you will need.
1. You will need to buy a set of block off plates for your particular setup. Go on ebay or talk to Kevin (rotaryresurrection)
2. You will need some vacuum lines, coolant line and 5/16" fuel line and related clamps.
Old 11-03-2008, 04:33 PM   #3
www.rotaryresurrection.com
Old 11-03-2008, 04:40 PM   #4
SpooledupRacing
Guest
Posts: n/a
depending what state u are in check your ordinance and make sure u wont have to qualify for a emission test.
egr removal, ACVC removal, rats nest removal, a little vac line and some coolant hose easy enough..
go to the above link and Kevins writeup is very nicely done!
there are many places to buy the block off plates..
Myself (Spooled up Racing)
Dan Atkins (Atkins Rotary)
others.
Old 11-03-2008, 04:46 PM   #5
Red Dragon
Rotary Enthusiast
Red Dragon's Avatar
Cool! Thanx alot, I will be checking all of this shortly.
Old 11-03-2008, 11:58 PM   #6
it's pretty easy. I know that Kevin wanted to redo his website and make a better write up, but I'm acutally trying to get a write up on this going as well as an article for RCC digizine...
dont hold your breath through, it might be a few months into the winter!
I know that when you do emissions removal, you want to send your injectors out, which is about $80 at either witchhunter or KG parts
Then you need about 10 feet of fuel line, I got 10ft, and replaced ALLL my soft hoses, including the ones in the back by the fuel tank, and I still got about 3 feet left!
(doing the rear ones is a bitch btw, it involves lowering the swaybar so you can get to the clamps, and etc)
I would also get a new fuel filter, and do the banjo bolt mod NOW since it's an S4 and you dont want it to catch on fire. (you use a banjo bolt to replace a "fuel pulsation damper" which often goes bad, and gives you an engine fire, is expensive to replace, and the car runs fine w/o it on.
Then, I would get an S4 oil metering pump rebuild kit or block it off if you dont mind putting 2 stroke oil in the tank.
5/32 vaccum hose, you can get a 50ft spool of it on ebay, for CHEAP! Also get an assortment of vaccum nipples a 5 way vaccum splitter(for the oil injectors) a vaccum T or two, as well as a few more 5/32 caps cause you will run out of those.
umm... what else... you could give your intake manifolds a bath in the hot tank as well to remove any extra crap in there... I got that done at a carquest, they had a machince shop in the back.
I will add anything else I can think of.
I just did all this shit in the midst of putting another engine in my car.
Old 11-04-2008, 12:02 AM   #7
88turboii
destroy, rebuild, repeat
88turboii's Avatar
banzaitoyota sells the dual alt pully for cheap
http://www.rotaryinnovation.com/new_products1.htm
Old 11-04-2008, 12:46 AM   #8
Lol, oh yeah, that too! I was actually going to wait until I could get the dual pulley to replace my alternator belt, but it went, so I had to settle for just a single.
PS: You need to buy TWO new belts of the same size when you run a dual pulley, even if your old single belt is fine, you still have to replace it so they tenstion properly.
Old 11-04-2008, 05:58 AM   #9
SpooledupRacing
Guest
Posts: n/a
Just so i know EVERYTHING Max SUGGESTED is only that... you dont HAVE to do all of that to remove the emissions..
I did about 90% of that but it is all because I wanted to. you don't have to do all of that
Old 11-04-2008, 10:08 AM   #10
Yeah, I just thought I'd point out a few things you can get done while you're in there, and yes, a lot of IS optional.
Old 11-04-2008, 10:18 AM   #11
SpooledupRacing
Guest
Posts: n/a
Yeah dont get me wrong alot of that is deff stuff I did and recommend to do but I dont want him to get discouraged due to everything else listed...
Those are just things u could do..
I also think the banjo bolt mod is a MUST..
Old 11-04-2008, 11:38 AM   #12
Red Dragon
Rotary Enthusiast
Red Dragon's Avatar
Ok so I did a lil research and I don't think Alabama has any emission laws (someone chime in if I'm wrong). So which are the absolute musts to take off? I know that I can't remove air pump since the car will not operate properly with it being NA and all. I have already removed cats, but thats about it.
Old 11-04-2008, 12:27 PM   #13
Your NA is an S4 right? Then your 6 port is actuated by back pressure from the exhaust, so you can remove the airpump.
Old 11-04-2008, 12:44 PM   #14
Red Dragon
Rotary Enthusiast
Red Dragon's Avatar
Ah cool! That should shed a few pounds.
Old 11-04-2008, 12:45 PM   #15
SpooledupRacing
Guest
Posts: n/a
exactly on S4 n/a u can remove the air pump (just get a couble alt pulley so u can run two belts
remove:
egr valve
acv
rats nest
bac valve (or I did atleast)
cats (u said already done)
remove the pulsation dampner and do the banjo bolt mod
check your omp tubes and make sure they are good or remove and block off the omp
and premix
make sure u have intake gaskets on hand (Mazda, myself or Atkins can help u with those)
get some vac hose (good time to replace all vac hoses to silicone) ebay or myself can help with that.
could be more but those are a good start.
