Old 10-24-2008, 03:18 PM   #1
Wtf?
Hey guys, my dad just got a 83 FB with 12a. I think the motor locked up. It drove fine last week and started just a few days ago. When I tried to crank it today, nothing. Pulled the starter off and had it tested. Its good. Then I tried to turn the motor over with a ratchet and socket. I pulled the plugs out to make it easier and the starter is still off and the tranny in neutral. I cannot get it to turn over either direction by using the ratchet and socket. Any ideas of what has happened? Broken seal wedged? Bearing failure? Any advice is greatly appreciated. Thanks in advance.
Old 10-24-2008, 03:24 PM   #2
Get a bigger ratchet!
Old 10-24-2008, 03:29 PM   #3
It shouldn't be real hard though with the plugs out right? I mean most engine I have seen can be turned over by hand. I will get a pipe this weekend to get more leverage tho.
Old 10-24-2008, 03:32 PM   #4
Something is making it stick. I would say a piece of carbon is lodged in there. Either you will break it loose, or break a seal. Flip a coin!
Old 10-24-2008, 03:39 PM   #5
So just turn it with a breaker bar... Should I try turning it backwards first?
Old 11-25-2008, 03:29 PM   #6
rx4ur7
Rotary since 1972
rx4ur7's Avatar
If there is carbon lock(common with motors that have sat) taking plugs out and turning backward can be done. Once you turn it over backwards a couple of times you can usually marvel or any other approved goo and turn in normal direction. If you can get it to turn a few times by hand then turn to starter. If it locks again, try backing it up by hand again. And go through the procedure again. If carbon locked that will usually work. If the motor has 150+K miles could be worn out apex seal lands and worn out bearings.
Please don't use the 6-9 ft breaker bar method, you could break a perfectly good apex seal.
Old 10-24-2008, 04:17 PM   #7
PercentSevenC
Custom User Title
PercentSevenC's Avatar
I would try soaking it in MMO rather than risk breaking it if it is just some carbon.
Old 10-24-2008, 04:26 PM   #8
How would I do that? Pour it in the spark plug holes?
Old 10-24-2008, 04:40 PM   #9
brycerxer
brycerxer's Avatar
brycerxer is on a distinguished road
Do NOT force it to turn unless you want to rebuild the engine. Read this before you do anything:
http://www.rx7club.com/showthread.ph...hreadid=281207
Have you considered taking the belts off and trying to turn just the crankshaft? Because usually cars only carbon lock from sitting for long periods. Maybe one of the other componants is locked up such as the air pump, alternator, a/c, water pump, etc.
brycerxer is offline   Reply With Quote
Old 10-24-2008, 04:58 PM   #10
I will look at that link. I have turned all the accessories and they all turn independently.
Old 10-24-2008, 05:40 PM   #11
Woops!
Sorry Nate, I forgot the whole MMO thing. Yes put a cap full in the spark plug holes.
Old 10-24-2008, 07:38 PM   #12
REDLINE SE
BOOSTED 84 GSL-SE
REDLINE SE's Avatar
REDLINE SE is on a distinguished road
Good luck with that.
I like your Sig Pic...
Babies are bottle fed, real men get BLOWN!
REDLINE SE is offline   Reply With Quote
Old 10-27-2008, 08:11 PM   #13
Solved lol... Turns out the slave cylinder bolts were way too long and hitting the flywheel
Old 10-27-2008, 08:13 PM   #14
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Wow, didn't see that one coming. Any damage to the flywheel?
Old 11-25-2008, 05:33 PM   #15
Has run fine for a few weeks so guess not
