Old 09-08-2008, 02:06 PM   #1
maui_boi
FC Rotary Power
maui_boi is on a distinguished road
My FC turns over but not giving spark
someone can help me plz my car turns over but there is no spark going to the spark plugs help me out plz o yea and its a 88 n/a
maui_boi is offline   Reply With Quote
Old 09-08-2008, 02:07 PM   #2
this is the same for both the leading and trailing?
did you check the fuse in the engine compartment?
Old 09-08-2008, 02:08 PM   #3
maui_boi
FC Rotary Power
yea for both not giving
yea and the fuses are good
i also just changed the spark plugs
Old 09-08-2008, 02:14 PM   #4
hmm...well i would then assume that you have no signal too the coils. BUT i would check that as well. Just use a voltmeter and see if you are getting signal to the coils or not.
If not, i would then pursue what can affect cutting the ignition. Without my FSM stuff handy (at work) i dont want to speculate, but i have a similiar problem that is caused by a loose wire in the harness. Generally i just move the harness around and its fine for a few days. Not sure what it is, but it would lend me to believe there is a component that can kill the ignition signal.
does your tach work while cranking? ie does it bounce due to the starter cranking the engine?
Old 09-08-2008, 02:20 PM   #5
maui_boi
FC Rotary Power
no the tach dosent bounce
Old 09-08-2008, 02:22 PM   #6
so you have NO tach movement at all then right?
Old 09-08-2008, 02:24 PM   #7
maui_boi
FC Rotary Power
nope but my cluster does work though
Old 09-08-2008, 02:25 PM   #8
okay. i think we have a similiar issue going on, only your is more permanent.
let me look over some wiring diagrams tonight, ill get back to you tomorrow on this.
Old 09-08-2008, 02:28 PM   #9
maui_boi
FC Rotary Power
ok thanks
anyone else got suggestions???
Old 09-09-2008, 06:52 PM   #10
maui_boi
FC Rotary Power
any other suggestions??? also im hearing that there is a test mode or something like that how u do that????
Old 09-09-2008, 07:10 PM   #11
I always throw in the "Check your main relay" advice.
Check your CAS (Crank Angle Sensor) and make sure everything is plugged in/perfect.
What have you done so far?
Check out this thread (READ IT ALL) and then check out the post about the TPS and ECU Code tester (post #7):
http://rotarycarclub.com/showthread.php?t=1790
This one also has a GREAT Article on the FC's Ignitions systems.
Old 09-09-2008, 07:19 PM   #12
maui_boi
FC Rotary Power
im thinking it could be the ignition because when i bought it the guy had put in a push start button and dosent turn with the key
Old 09-09-2008, 07:26 PM   #13
why didn't you say that from the beginning then?
GO back and check his work and make sure ignition works.
You can even go ONE better and take a video, post it on youtube and show us.
Just add RotaryCarClub in the video description while you're at it.
Old 09-09-2008, 08:45 PM   #14
maui_boi
FC Rotary Power
my ignition works cause my main relay clicks
