sa rat rod
12a to 13b turbo mani adapter. will all dims need
hey guys i was up late last night and found a print for making a adapter plate for mounting the TII turbo mani to a 12a. the print did not have all the dim's need so i figured id use a cad program i have and figure it out for you guys.
parts needed. to make this a 13b flange and 12a flange. 5 inches of 1.5 id tubing. i was reading this would be the best tubing to use so it keep the exhaust speed up. use what ever id tubing you want tho. i do not know who made this print in the first place so please do not sue me lol. ![]() mark the tubing at 58 deg then slide protractor up 2.353 inches or slightly less then 2 and 3/8 Th's. then cut on your lines and repeat. i figured id help you guys out since iam going to be trying to turbo my 12a. (i know i didnt use all the correct wording but hey i only got 2 hours of sleep cause this stuff was bouncing around in my head.) |
#2 | |
Very interesting and valuable tech.
sa rat rod
thanks i dont know enough about our motors but i learning. i do know welding,tube bending ,machining and basic cad so i figured that could help some people out at least.
