Old 07-17-2008, 07:57 AM   #1
How Air "Works"
From my experiences with the internet, it's apparent to me that there is a general misnomer about how air "works". Many websites, internet forums, etc tend to haze over the truth of how air acts in both the form of exhaust and induction. It is my intent to correct this and give you, the reader of this long thread, a dumbed down, yet explicit explanation of why air does what it does.
INTRODUCTION
First off, air is a fluid. The textbook definition (literally out of a text book) of a fluid is "a substance that is unable to resist the application of a shear force without undergoing a continuing deformation". (pg.2 of Introduction to Fluid Mechanics). So what does this mean? Its mean that in order for something to be labeled a fluid, it must not resist a force parallel to it. Think of a can of Pepsi sitting on your counter. Without the solid, tin surrounding the liquid contents, the cola would just be a puddle on the counter. Gases behave the exact same way.
So because air is a fluid, it has to follow some rules, the biggest being that air is a compressible fluid. The second most important is the "Conservation of Mass". The "Conservation of Mass" basically means that if you put mass into a system, you should get the equivalent amount of mass out. Granted there are some exceptions and a few of which stem into math that i frankly, don't understand. Now keeping this ideas in mind, I'm going to explain how air works in two of the most important parts of our engines operation, induction and exhaust.
AIR AND INDUCTION
Induction is obviously the intake track leading to the combustion chamber that gives the engine the fresh air it needs to operate. If you didn't already know this, it saddens me. And frankly, i have no idea why the hell your reading this. But getting back on track, induction can take on two methods. These are as follows:
1. Forced Induction - the absolute pressure is limited only by that of the device forcing the air.
2. Natural Induction - the absolute pressure is limited to that of the atmospheric pressure generally (14.7 psi at sea level)
Lets look at natural induction first, even if it comes 2nd on my list.
Natural Induction
Natural induction is probably the most widespread form of induction you will find in the automotive world, regardless of my want to see turbochargers and superchargers (or both) on everything, that is the sad reality. What happens is as your engine draws in air, a vacuum is created due to the pressure change resulting from the air entering the combustion chamber. This is where the name "induction" comes from. Air (or anything under pressure for that matter) will move from the area of higher pressure to lower pressure, meaning it will be drawn in to file up the "void". At wide Open Throttle (WOT) conditions, this vacuum is generally not able to be read on a gauge because the air entering the combustion chamber is easily replaced by air coming in from the outside, which at sea level is at an absolute pressure of about 14.7 psi or 101 kPa for those rocking the metric system. Why your standard everyday gauge will not show "14.7", but instead "0" is because it is reading something conveniently called "gauge pressure"; which is the reading of the pressure about that of the atmosphere. When the throttle plates are closed, the mass volume of air entering the engine becomes significantly limited and the vacuum will build up inside the intake manifold. This is become the mass volume entering the engine is greater than that passing through the throttle body so the vacuum is created.
Forced Induction
Start shoving air into the intake track at pressures above that of the atmosphere, you'll have yourself forced induction. In the WOT condition, the air entering is forced passed the throttle plates. When the air enters the combustion chamber, the pressure instead the chamber equalizes to that of the entering air. In a sense, the air being drawn into the chambers during natural induction is actually being forced in at a set pressure of 14.7 psi. Forced induction is merely the result of these pressure going above the atmospheric pressure. This can be achieved by several methods, most commonly the turbocharger or supercharger. Hell, "ram air" induction will generate a pressure above atmospheric, but the vehicle would have to being moving at a few hundred miles per hour to see any significant benefit. Other methods exist for creating small increases in pressure, but they are generally to complicated to explain here.
So why does forced induction created more power? That is for two reasons, one is that the cylinder pressure increases, and more importantly, more burnable oxygen is forced into the chamber. And now is where I'm going to bring in some math:
Density = (pressure) / (Temp x Gas Constant) [ D = P / RT ] and
Mass Flow = (Density x Velocity x Area) [ M = DVA ]
In order for more oxygen to be in the charge, you need more density. This is why cooler air yields more power, as cool air is denser than heated air. Why? Well look at the formula above for density. If the temperature increases, then the density will decrease. Whereas, if the pressure increases, the density will increase. So if we run about 15psi from a turbocharger, that is roughly double the amount of oxygen coming in IF THE TEMP REMAINED THE SAME. Compressing air will create heat. Turbochargers generally create more heat due to the proximity of the exhaust. This is why intercooling works so well, since it has a minimal loss in pressure but reduces the temperature thus giving us a improved density and the ability to run more pressure without melting holes in pisons, which is a whole other topic.
So what about the "mass flow" formula? Well that comes into play in our next sections: Induction (charge) piping and exhaust.
Old 07-17-2008, 07:58 AM   #2
INDUCTION (charge) PIPING
Welcome to my next section where i attempt to get you to understand what makes a "good" design and a "bad" design in regards to piping. Before we continue, i have to explain "mass flow" that was shown above. You need to understand what is happening in the formula to see why air behaves like it does in certain situations.
recall that: Mass Flow = (Density x Velocity x Area) [ M = DVA ]
So that means Mass Flow (M) is proportional to Density (D), Velocity (V) and the Area (A). Plainly, if you increase either D,V, or A, you will increase M. If one decreases, M will decrease. If they all change randomly, then it just depends on it multiplies out. Now also take into account the "Conservation of Mass" meaning that M[sub]1[/sub] going in will EQUAL M[sub]2[/sub] going out unless something is destroying the mass or its being diverted somewhere else. If you get this, then feel free to move on. If not, google.
There are some key ideas that you should follow when designing your charge pipes and for that matter, your entire induction track (head, charge pipes, throttle body, etc). These are as follows:
1.) Use the least number of bends at possible.
Why is this important? Air is a gas. Gases are kinetic, IE move around a lot on an atomic scale. This means they create more friction that say, water would. So when the air is moving through a bend, more friction is created than the straight section. This will slow the velocity of the air. So if the velocity does down and the density and area are the the same, then the mass flow would also have to go down. But the mass flow can not go down. So if the area can't change, then only the density of the air can.
D = P / RT
If you look again at the density formula you'll see that the pressure would have to decrease or the temperature increase, in order for the density to decrease. R is again a constant. Usually it is a combination of Pressure loss and Temp gain.
2.) Limit the change in diameter of the pipe as best as possible
The air will only flow as well as the smallest area in the pathway. So if you have a small throttle body and large charge pipes, it is no better and sometimes even worse than having smaller charge pipes. Even if you increase the throttle body size, the port runners of the intake manifold can present a problem. The reason why this happens is because of a few factors.
A.The Mass Flow rate is reduced. As stated, if the pressure and density are the same, but the area decreases, then the mass flow will decrease.
B. The areas where the diameter increases and decreases generates more friction and was i have previously noted, that isn't good. This will ALSO cause a decrease in mass flow rate due to the pressure loss resulting from the reduced velocity.
There are other factors that make up a "good" design such as overall length of the piping, but that is more for reasons of lag time, etc and is not the focus of this article.
Old 08-06-2008, 02:32 PM   #3
Dr-Rotor
Dr-Rotor's Avatar
Dr-Rotor is on a distinguished road
Is that it? I thought you were getting to a point and some exampels. None the less very good info for all. Perhaps this would explain my rediculouse power figures. Take a look at my setup that includes water injection to drop the charge temp and increase density. Power was recorded on a dyno dynamics at a ramp rate of 110. GT3582R rated at 700hp for pistons in the largest 1.06 AR. At 20psi mine recorded 588rwhp....thats just insane compared to what others have achived. What do you think?
Dr-Rotor is offline   Reply With Quote
Old 08-07-2008, 08:56 AM   #4
this article is just about the theory of way, a lot of your setup im sure is thanks to tuning.
Old 08-07-2008, 02:00 PM   #5
Dr-Rotor
Dr-Rotor's Avatar
Yea probly. Thanks for the info anyway.
Old 08-07-2008, 02:04 PM   #6
well, let's discuss it.
Old 08-07-2008, 04:42 PM   #7
Dr-Rotor
Dr-Rotor's Avatar
Id love to. What part of it all would you like to start off with?
Old 08-07-2008, 04:56 PM   #8
Dr-Rotor
Dr-Rotor's Avatar
Haa I know something about air flow we can discuss.
Ever wonder if there is a difference between having the IC right up front or further back in the engine bay with ducting channeling air into it. We have been discussing it at the work shop for the past few weeks.
We had a car on the hoist with a stock bumper and FMIC....we put compressed air through it & you can feel the air that dose not make it through is wasted & spills over the sides....to me this dose not seem all that efficiant. I think an IC set further back with ducting panels to stop the air from escaping is better. My reason for this is that the air is forced into a space that will contain it. Air can be compressed so this would mean that the air that dose not flow through will hit the side of the ducting then be turned & forced back through again by the continuouse pressure of on coming air as the car picks up speed. Therefor minimising the loss of pressure over the face of the IC & increasing its efficiancy to cool & also helping the radiator to recive more air.
Now many companys have turned to V-mount but one tuner (Fujita) still use FMIC. Must be a reason they favor FMIC setup. Could be as simple as its easier to setup & duct perhaps. I could be wrong, who knows.
What do you think?
Old 08-07-2008, 05:17 PM   #9
Dr-Rotor
Dr-Rotor's Avatar
Some examples
Old 08-07-2008, 08:31 PM   #10
ok, so, based on the info and your setup I cannot imagine a more efficient hot side piping. Your cold side looks odd to me but then again I never liked the FD TB elbow but it still doesn't have too many bends. The FC one seems better to me but no matter what there is still a 90* bed to the UIM. You're still decreasing the the amount of density loss which just means a few more HP...
Then take into account that IC and Radiator seem to be well insulated from the engine bay heat. Plus your turbo blanket, plus the water injection, along with the vented hood. You're decreasing the amount of heat that the IC pipes would be exposed to and keeping the air cooler and denser at the manifold. Little by little you make more HP.
Ducting just rocks. I think it allows for the air to be forced through in an easier manner than without it. If you duct it right you can force cold air in then isolate the hot air from the IC, radiator and oil cooler right to the vents on the hood without exposing the IC pipes to it.
I've been contemplating heat-wrapping the IC pipes to keep the air cooler in the pipes.
Old 08-07-2008, 08:37 PM   #11
I like YOUR hot side IC piping with this cold side piping:
The venting I'm talking about is like this; Mind you this is an NA 3 rotor but he's doing the same thing. I solating the hottest air from the intake.
This car is bad-ass:
Click to check out the rest of the car.
Old 08-07-2008, 11:11 PM   #12
josh18_2k
on the topic of less bends.. why are turbos never mounted vertically?
the downpipe would point down (where it has to go anyway) and the charge pipe would come directly off the turbo into the intercooler. 2 90 degree bends eliminated.
either mount the filter strait on top, like so many do already, or have a bend there. its on the suction side, so its probably of slightly less importance.
Old 08-08-2008, 02:59 PM   #13
probably has to do with the gravity powered nature of the oil return
Old 08-09-2008, 03:00 AM   #14
Dr-Rotor
Dr-Rotor's Avatar
Yea so true....there will always be something that hinders ideas like vertical mounting.
Speeking off the DP im not sure what you guys have but mine dose not seem to be 90deg off the back....its quite a stuttle bend.
Old 08-09-2008, 03:04 AM   #15
Dr-Rotor
Dr-Rotor's Avatar
Phoneix...I hear ya pal....Im going to change my setup to that top pic....keep my hotside as is & make the cold side staighter. Also I am going to half the nozel size of my WI on the elbow & add another nozel to the hot side before the IC. This will cool the air even more & also provide the Rad with cooler air.
