Rotary Enthusiast
Idle problems
Ok I own a NA 87 RX7. Whenever I crank the car in the morning time the car revs high then after it will rev at about 1K. Then maybe a few seconds later it shuts down on its own. The thing is, once the car warms up a little the car doesn't shut down but it idles at either 500 to 800 rpms (not sure if thats normal). Are there any ideas what the problem could be? And sorry for the poor description, this is my first time dealing with a rotary.
N/A 1987 RX7 (restoration coming along) |
Intake vacuum leak
TPS bad or out of spec Dashpot not adjusted properly Idle not adjusted properly via BAC valve, idle set screw, etc. |
normal
this is normal, supposed to be for heating up the exaust. Happens when car is in neutral on cold starts. put it in gear on start up and it will idel normal 800-850
Rotary Enthusiast
ok I'll try that
#5 | ||
Rep Power: 20 ![]() |
Check your TPS make sure it's reading 1v if you're setting it via voltage test style. I would also highly recommend upgrading your ECU to RTek2.1 and don't look back. But then again it might be more than you want or need... but come on you know you want to. Do it. Come on. It'll be fun.
#6 | |
Rotary Enthusiast
I also have an 87' a good piece of information would be whether it sustains the 3000 rpms for a few seconds or not. If it does then your fine 750 rpms is what they are supposed to idle at. If you look on the inside of your hood thats what it says. when you start it up in the morning it may be shutting off because its still running a little to rich, give it a little gas for a few seconds and it will clear up it literally just sounds like it needs to clear its throught, once it leans out it will be good.
Guest
Posts: n/a
yeah reading that again it sounds like the cold idle assist
its normal and its fine |
#9 |
Rotary Enthusiast
You got it right on the head. That's what I usually have to do in the morning.
#10 |
Fried Chicken
I had the same problem and I juice it a bit, and it idles fine.
87' GXL Rx-7 97' S10 Ext Cab~DD
