Go Back   Rotary Car Club > Tech Discussion > RX-7 3rd Gen Specific (1993-2002) > Archives
Archives Where all the stickies are
Old 02-28-2008, 06:17 AM   #1
RotaryBuddha
RotaryBuddha's Avatar
RotaryBuddha is on a distinguished road
Vacuum Diagrams
I don't take credit for these diagrams. Just posted them on my photobucket, and posted them here for archive purpose.
RotaryBuddha is offline   Reply With Quote
Old 03-04-2008, 10:56 AM   #2
blwnrtr93
blwnrtr93's Avatar
blwnrtr93 is on a distinguished road
non-sequential
simplified stock twins
blwnrtr93 is offline   Reply With Quote
Old 03-04-2008, 11:39 AM   #3
My5ABaby
My5ABaby's Avatar
Could those be MORE complicated?
Old 03-04-2008, 11:45 AM   #4
blwnrtr93
blwnrtr93's Avatar
About the stock vaccum line configuration I wonder, how many hours of training it took for each employee dealing with vacuum line hook up at the Hiroshima plant?
Old 03-04-2008, 12:55 PM   #5
SPICcnmFD
SPICcnmFD's Avatar
It does take a while to figure out if you are working on your car.
I still don't like how it's called "simplified seq." All it is, is the seq. system with basically all the emissions removed, it really doesn't simplify the seq./turbo vacuum hoses at all.
Old 03-31-2008, 07:42 PM   #6
sm0keyii
sm0keyii is on a distinguished road
Yay, an easier single turbo diagram *right click and saves* Thank you ^_^
sm0keyii is offline   Reply With Quote
Old 06-24-2008, 11:18 PM   #7
so, anyone know where to get an FC version? TII specifically. I searched and haven't been able to find anything yet.
Old 03-01-2009, 05:39 PM   #8
MOBEONER
MOBEONER's Avatar
MOBEONER is on a distinguished road
i have been braking my head trying to figure out a better way to relay simplify the vacuum diagram. i personally believe that Mazda`s engineers did a very good job designing the the vacuum system and its very impressive how it works.on the lighter side i also believe that they had a little too much coffee in the process.i was just discussing the importance of the vacuum chambers in the other forums and as of yet i haven't been able to figure out a real reason why from what i can tell the turbo control solenoid valve is that intricate and sensitive that you need two solenoids (h and f) for charge and relieve along with a vacuum chamber box for it to maintain a certain amount of pressure.how many psi does that closed system needs to hold with in that loop for that turbo control solenoid to work? it works only on vacuum i don't see why it was 3 intake connections that can only work on vacuum just to control the lower actuator.
Hit em and run plumbing
MOBEONER is offline   Reply With Quote
Old 04-24-2009, 04:38 PM   #9
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
hey for the simplified seq set up- are block off plates needed? the only one i have is the acv block off plate at the moment
muibubbles is offline   Reply With Quote
Old 06-19-2009, 02:07 PM   #10
muibubbles
Bubble Tech
muibubbles's Avatar
hey where does this line connect to? from the original diagram it connects to the pressure chamber but in the simplified the pressure chamber is moved... so should i just block off this line?
Old 06-22-2009, 08:51 AM   #11
SPICcnmFD
SPICcnmFD's Avatar
It still goes to the pressure chamber if you look at the LIM you can see a line that connects to it has a check valve on it that doesn't go anywhere, thats this line.
1993 Rx-7 SM2 #11
At the local AutoX:
http://www.youtube.com/watch?v=9VOSQkkSLQs
Speed for Sale shootout 2007:
http://www.youtube.com/watch?v=JiqlyAkGmpg
A few laps at Barbers:
http://www.youtube.com/watch?v=6_h5q...x=0&playnext=1
Old 06-10-2011, 11:07 AM   #12
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Wanted to post my plotter size diagram http://www.filedropper.com/fullpagephoto it's
40x28 here's how it looks
Old 06-10-2011, 11:37 AM   #13
You should frame that
Old 06-10-2011, 11:43 AM   #14
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I've printed about 4 of them now. 2 are framed at friends houses 1 in my garage and 1 rolled up waiting a frame
