Old 05-05-2008, 05:01 PM   #1
Oxygen sensors..
OK.. By looks of it, there are two O2 Sensors on the 8..
Which one is used for idle??
Also, they are kind of expensive!! Can the O2 sensors be cleaned and re-used?
Old 05-05-2008, 06:37 PM   #2
-xlr8planet-
-xlr8planet-'s Avatar
Probably both are used to idle the car.
but if not, the one closer to the exhaust port.
The other one (after the cat) is mainly for emisions purposes
Old 05-06-2008, 10:34 AM   #3
Nexcis
Nexcis's Avatar
Nexcis is on a distinguished road
You can go to autozone and buy one of their cheaper ones. All O2 Sensors are virtually the same, the price difference is mainly the specialized plug on the end of the wires. It wont have the correct plug (or any plugs for that matter), so you'll have to do some soldering.
'94 VR FD - Mod List
Nexcis is offline   Reply With Quote
Old 05-06-2008, 12:04 PM   #4
Just checked Advance auto and O2 sensors are about the same as the dealer price... Dang!
Old 05-06-2008, 09:15 PM   #5
Nexcis
Nexcis's Avatar
Did you price the O2 Sensor that would fit your car or a universal one? I just went to AutoZone and they have several ranging from $70 (Post Cat) 4 wire Universal, others for ~$180 for Heated O.E. style.
Old 05-07-2008, 02:19 PM   #6
Oh, it was for the 8 specific from advance..
I read more stuff last night and apprently O2 doesn't affect too much on idle...
Old 05-07-2008, 06:59 PM   #7
OK.... Update...
I got some input from other rotary guys and decided to do some checking..
I tried to clean the crank angle sensor (which I couldn't reach) and other things... and when I started the car, it cranked and died about 3-5 seconds later..
I then cranked it again and it started but ran kind of rough and made some noise under the hood. So, I decided to check it out and started to touch few things here and there... And when I finally moved some wires.... all the sudden, car idles perfect!!!
I can't fucking believe this fucking car is so sensitive! I've now tried and cranked several times and each time, idles perfect! I'm going to see tomorrow morning and see how it starts... Thats going to be the real test!
Old 05-07-2008, 07:50 PM   #8
so you have a loose wire? Try and see if you can find the loose connection before driving it. You don't wanna get stranded somewhere.
Old 05-07-2008, 08:49 PM   #9
I don't think its loose wire...
I let the engine cool back down and I crank the car again..
Car started right up and idled up to 2K RPM... then, it started to idle back and forth (hunting) around 1k to 500RPM... and eventually settling back down around 1k to 800ish RPM.. During the hunting, car ran kind of rough.
I let the car warm up, shut it down, and cranked it again. It cranked right up and idled perfectly.. Again, I'm having the same similar issues..
Old 05-07-2008, 10:06 PM   #10
fikren
fikren's Avatar
fikren is on a distinguished road
I'd check your connections Phil, it kinda does sound like a loose wire somewhere. You might also, when you get some time, either put on a premade grounding kit or one of the do it/make it yourself ones. Its probley something fairly simply annoying as a loose wire that made better contact when you were pulling on things and made the idle decent and finally settled back out in a less than desirable connection from the motor vibration.
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
Old 05-07-2008, 10:43 PM   #11
As far as the erratic idle at cold start: I'm thinking a leaky injector flooding the motor and making it idle weird when it turns on?
If you tap the gas will the car settle down? By tap I mean a mini tap, not even 200rpm. Try it at the next coldstart to see if it settles itself.
Old 05-08-2008, 07:01 AM   #12
I've drove the car this morning to work... Started up fine, but start to hunt and died. Cranked it again and everything was fine. I drove 7-10 miles to work and everything was fine!
Ive checked pretty much everything.. I think after this weekend, I'm just going to take it to the dealer and ask them to plug it into their diagnostic machine... Luckily like everything else, I have some engine parts laying around at home.. Just need to find it
