Go Back   Rotary Car Club > All thing Racing! > AutoX Nuts!
AutoX Nuts! If you are one, post your set up, questions, etc here!
Old 07-28-2017, 10:04 AM   #1
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Tires, Sidewalls, Things
I'm eventually wanting to get into some auto-x and hpd so I'm trying to figure out a good wheel and tire set up. I have been considering 16" and 17" wheel options and I'm curious how side wall height will effect performance.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 07-28-2017, 03:42 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
You will need to go with at least 17s if you want a good sticky tire for autocross. Anything smaller is very hard to find good performance street tires for anymore. There are race tires for the smaller sizes, but that could get expensive fast. The lower the profile of the sidewall, the more responsive the tire will be to changes of direction, downside being that the lower the profile of the sidewall the harsher the ride will be. Your choice on what balance you want to make.
Old 07-28-2017, 04:05 PM   #3
project86
project86's Avatar
Ok that makes sense. What about the sidewall flexing enough that the lips of the rims get messed up? I feel like I’ve heard of that happening from hard cornering. Is that a thing?
'90 GTUs
'10 Toyota Prius
Old 07-28-2017, 04:34 PM   #4
GySgtFrank
GySgtFrank's Avatar
Yes, it can happen with low profile sidewalls. Especially hitting rocks and curbs. Which is one of the reasons why most off road vehicles run a tire with generous amounts of sidewall.
Old 07-31-2017, 11:49 AM   #5
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
You can get good autox rubber down to 15". Anything smaller is NLA for rdot or summer performance tires. I have Dunlop Direzza *2 on my 15" Konigs on my SA and they are an excellent tire. Had to relearn to drive my car when I put them on. Tons of grip and one of the better rated autox tires out there as of 2016. Mine are 205/50x15. Keep the pressure up on autox days and you shouldn't have any issues with the rims being damaged. On the street I run ~33psi but if I'm doing any real driving I pump em up to about 38psi or so.
Old 07-31-2017, 02:52 PM   #6
project86
project86's Avatar
Good advice on the pressure. I'll have to keep that in mind.
'90 GTUs
'10 Toyota Prius
Old 08-01-2017, 08:58 AM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
Yeah, 15" wheels have good performance tire options because of the Miata guys. I can't remember if the FC's can fit 15" wheels over the front brakes though. Outside of actual race rubber, there aren't many 16" options left. I did the math once too. I compared the wheel of 16" RPF1's with 245/45R16 tires to 17" RPF1's with 255/40R17 tires. The overall weight was within a 1/2 lb or so (17" heavier) and the 16" combination puts the rotating weight slightly closer to the hub.
Old 08-01-2017, 11:08 AM   #8
project86
project86's Avatar
Is that more desirable?
'90 GTUs
'10 Toyota Prius
Old 08-01-2017, 11:30 AM   #9
FC Zach
FC Zach's Avatar
BBS vert wheels are 15" aren't they? I could go look at my car outside but I'm too lazy at the moment.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 08-01-2017, 01:27 PM   #10
project86
project86's Avatar
I thought they were 16"....
'90 GTUs
'10 Toyota Prius
Old 08-02-2017, 07:24 AM   #11
infernosg
IT'S ALIVE!
infernosg's Avatar
Without going into too much detail the closer the center of mass is to the point of rotation the less inertia it has. Basically, it's easier to accelerate/decelerate. It's why racers use small diameter, ultra-lightweight flywheels.
That's a good point. I completely forgot about those. I never calculated the weight of a 15" wheel and tire combination. I was looking at RPF1's and they don't come in a 15" wheel with our 5x114.3 bolt pattern. Depending on the wheel and tire widths and tire sidewall I'm sure it could be even lighter than the 16" combination but at some point you're trading weight for contact area and sidewall flex.
Old 08-02-2017, 09:40 AM   #12
project86
project86's Avatar
Speaking of RPF1s.... They are pretty well known for being a great light weight option right? I've noticed manufactures aren't providing wheel weights on their spec sheets (that I've seen). I like the RPF1 but I'd prefer a different wheel just for the sake of having something a little different but I dont want 100lb wheels lol.
'90 GTUs
'10 Toyota Prius
Old 08-02-2017, 12:03 PM   #13
FC Zach
FC Zach's Avatar
The forged TSW wheels I was looking at stated the weight of their wheels. Their 18" option I was looking at was only 18 pounds!
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 08-02-2017, 01:55 PM   #14
Nutsid
Temporarily insane.
Nutsid's Avatar
The reason the RPF1s are so popular is because of cost, weight, and strength. There really isn't anything else in the price range that does what it does.
Tirerack does a pretty good job at posting up weights of the wheels they sell, but weight of tires matter, too. Buying super lightweight wheels is great and all, but if your tires weigh a ton then it obviously negates the benefits.
Kindle
Nook
Old 08-01-2017, 01:37 PM   #15
Nutsid
Temporarily insane.
Nutsid's Avatar
I heart 15s on my Miata with Bridgestone RE71-R's. I had a ton of choices for tires, too. I don't know the FC size, though, but it may be worth dealing with a speedo being off.
Kindle
Nook
