| Introduce yourself!! Tell me something about you and your history with rotary.. |
hello from New Mexico
Hello all, I am new to the site and looking for a lot of info. I have a very wide background in mechanics both auto and aircraft. I am a old time drag racer and car builder but have never touched a rotary engine but I know they fly. I am planning a build with a 1967 VW Bug, mid engine with a TH 350 and a 8.8 IRS. and am looking for lots of knowledge on what 13B to build. I have access to several late models both 7&8. ps the name is Dave
Professional Stick Poker
Welcome Dave. What are you planning to do with the car when finished. Drag car? Street? If you are looking for big power, you will need to build something with a turbo that can hold lots of boost.
My plans are for a drag car that can be driven some on the street sort of like my old C Gasser from the 60's did some fishing with that car. I would like to build a turbo motor but don't know enough to know what would be the best to build 4 port, 6 port something that started with a turbo and just go bigger. What do you people think?
#4 | |
#5 | |
Don Mega
WELCOME! First off the meet your stated objective STREET CAR that is drag capable. WATER INJECTION and pump gas is ALL you will ever need. I have many of them that embarrass full methanol drag only set ups! 13B street port (13B-RE or REW ported out to be RE spec runners with RE inlet manifold.) BW S369SXE (true 900bhp capable), fitted with Tial rear housing pump gas and RR water injection will do in that car 8's and 160mph range easily, simple reliable real street set up. Welcome again Other parts to use. Tial V60 Life Racing F88 ECU (full knock, lambda, traction control etc) ALL WORKS! not internet hype but as used in LeMans 24hours! I have fully developed rotary engine calibrations and full support for these for anywhere in the world 4 x 2000cc injectors RR water injection system Steel Science apex seals RR coil on plug and M&W pro drag street RR CDI set up All proper items not a microwreck or 400 add on dildo boxes of cheap nasty electronics
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 12-11-2015 at 07:34 PM. |
Don Mega
4 ports, RR street ported is all you will ever need. There is allot of total bullshit out there and much wasted effort spent on total crap! like extra peripheral ports and totally butchered housings.
I have the largest and most correct validated data base of rotary engine knowledge anywhere in the world on porting and turbocharging, once you know how to separate the fact from bullshit (takes more than a couple of days on the dyno lol) it is real easy to see that you need nothing more than a correctly done street port and selecting the best OE inlet manifold, that currently is the 13B-RE or COSMO, the REW is a much better engine base and it is easy to port out its inlet runner shape to accept the RE inlet manifold, this then makes the best base engine for your application. On a real simple level looking at the highest boos levels on the turbo I told you about above for street use and using a Tial 1.06A/R V band housing on a basic linear scale as you increase MAP 1bar 225bhp (0 boost) 2bar 450bhp 3bar 675bhp 4bar 900bhp (43psi boost) You actually make more power at the lower MAP levels due to higher Ve in those ranges but the above suffices to paint the picture for you. This is all set up on very conservative engine calibration that will live for years on gas and water injection, dozens of cars running this way, all proven and NOT ONE E85 or ethanol FUCK UP NIGHTMARE ever to deal with! EVER! Simple Reliable, world leading.
Thank you for all of the information. That will be a great help. Sgt Frank not to sound like a smart ass, but why would a TH350 be more of a problem than a Mazda auto ? I was planning on a 350 or a glide with a high stall and a trans brake. But like I said I no nothing about Rotary Engines.
How much water is being injected at that boost level?
-75 RE_W_PU - -76 Hercules W2000 - DGRR 2012 3rd place Old School -75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month ![]() -Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP |
#9 |
Don Mega
That is a 'specific' detail shared with customers of mine only. However its 'normal' and in a drag car application you run many runs on one tank, many.
Street cars will go for a full tank of fuel on one tank of WI with normal duty of full power use. Circuit related a track session on one tank no problems even on high full throttle demand tracks.
#10 |
Don Mega
With the RR supplied Life Racing F88 its all tied into the calibration so if the WI tank is low or lost pressure for whatever reason (split tank eg) then it ties in with the boost, knock, lambda control, same for running WM50, unlike other inferior guess work ECU's and dildo box add ons everything is seemlessly integrated so even full load target Lambda is accounted for too.
Its a fool proof system. I also run Air to Air IC with WS assist system, even at those boost levels ACT is very low, very low! all coming for the same WI tank, and all true street! no ethanol nightmare on elm street blocked injectors or only being able to run the car in a 50 mile radius LOL or carrying mad max fuel drums in tow! and no problem ever running contaminated fuel that WONT be picked up on a E Flex sensor too!!!! Ethanol is a con! EFLEX JOKE! >
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 12-11-2015 at 09:04 PM. |
#11 |
Don Mega
There is zero need for 1000+hp the engine will be totally a turd, undrivable and NOT usable at all on the street with a power band of less than 1000rpm a total fucking shitbox disaster!
You can make a real engine, that is very powerful totally street use applicable and still dominates on the track, in a much heavier car combo I have them running low 8's at over 160mph! and the engine works and is proven. You are right you need someone with REAL WORLD EXPERIENCE and there is no one who has more than I have in making REAL ROAD CAR capable turbo engines. There is zero need to put on a turbo as big as the engine or gay ass semi pp or methanol or ethanol or C16 or scotch lock dunce cap #1 retard nintendo game boy sctoch lock hand set joke electronics with matching big sticker on your car. Be smart about it and make a quality set up man.
#12 |
Don Mega
The only saving grace of the auto set up on a 13B is that you can get away with a stupid sized turbo, but you will need to run a 6000rpm converter at minimum.
They absorb a retarded amount of power, I did one with a two speed glide and over a third of the engine power was wasted in heating up the gearbox oil via the TC, real nasty set up if you ask me, and you loose about 10mph off your top speed too. I would never do an auto gearbox on a 13B its just too slow, on the street with that TC you will need a radiator as big as one for the engine! they run stupidly hot and everything gets killed pretty quick! its just a set up that does not work well at all in reality.
#13 |
Lets try this again and make it short. I will be using the 5 speed that comes with the 13B FD3S engine. Car will be front engine and very lite. I need to research clutches for this combo. Rice Speed I was looking for prices for some of the items on your site . Coil on plug and your water injection kit.
#14 | |
Don Mega
