| RX-8 (2004 - Present) All things to do with RX-8 |
Where's the next apex?
Direction dependent vibration issue...
I have been having a weird vibration issues for the past few months. I can't tell if it has been getting worse. The vibration happens when traveling 50+mph (especially 60-70mph). The vibration is more noticeable when turning the steering wheel left (vibration becomes severe and whole car rattles). However, turning the wheel right makes the vibration go away completely (incredibly smooth like how the car should drive).
I don't have a reason to believe my alignment is off--tire wear seems to be OK. I've also visually inspected my suspension parts and cannot find anything broken or loose. The wheel bearings seem ok on the "wiggle the tire" test. There has never been any odd sounds (like metal clanking or grinding), only the vibration. I have rotated (back to front) and cross-rotated (left to right) my wheels yet there is no change in the vibration and direction. Any advice on what to try next? Thanks, FS
I don't get mad. I wait for you to apex early.
#2 | |
Rep Power: 17 ![]() |
Check your Halfshafts on the rearend Jack it up and have a good look around. Pay close attention to the inner CV near the Diff
Also look over the Driveline make sure all bolts are there and if the balance weights are still on it.
#3 | |
FS
#4 | |
What it sounds like is something on the right side of the car. Turning left you are putting weight on that side, and causes more strain. Turning right you are shifting weight away, and lessens load on that side. ^the above is a pretty typical indication of a wheel bearing, rear axle, or even a tire with a broken belt. (ie. Something that is moving/rotating) I once had an issue where the whole car would rythmically vibrate at highway speed, but couldn't pin it. I thought it was a wheel bearing. Turned out i let someone else driv ethe car while I followed, and the rear tire was moving around pretty violently. It just reached a strange resonance at that speed. Replaced the two rear tires, no more vibration. My point is, it can be something odd that you never expect.
Thanks. I plan to replace my wheel bearings. How difficult is it to do? Do I need to buy the whole hub assembly or is it cheaper to just buy bearings and have a shop press them for me? (I don't have many specialized tools with me)
Thanks, FS
#6 | |
