Rep Power: 15 ![]() |
NRG Harness Bars
Im looking at getting a NRG Harness bar for my FC. Has anyone on here ever used one before? Im curious about opinions or pictures anyone may have.
Wow I can't believe I missed this thread! I am currently running one in my FC ... but I the one I managed to fit in mine is for a Fox body mustang. So the size around 50" or so. I installed it for track day usage as the corning without restraints is a bit tough. I'm using Corbeau 3" 5 point harness. So mounting it was interesting cause I have automatic seat belts which left me to use the factory mounting holes for the rear seat harness which makes a lot more sense cause I've seen people bolt it to the rear hatch lift supports which is a bad spot for obvious reasons, not sure if it'll be the case for you for your model. The draw back I have from it is the storage bins only open about 45 degrees, I had to cut into my interior slightly, and I had to source out longer bolts to mount it. but other then that, I really am pleased how it turned out
Well Im glad to hear it turned out good and is working for you. One of my biggest concerns is the harness I have is a complete bolt on one, so Im not sure how I could attach it to the bar itself, or if i could cut off the mounting tab for the shoulder harness part and source a way to attach it to the bar with a wrap setup.
This is the model I have
http://corbeau.com/other/harness-bel...ness-belt.html if you can see what I mean about all the attchment points being bolt in style.
If you look at the pictures posted I wrapped mine around the bar. Pretty sure you could do the same with yours. Those hooks are removable, well for the rear at least.
awesome, always good to know then. where do you have yours bolted to in the rear?
Bolted as far as the side straps? Right where the stock ones are no need to change the position. Just I needed to get longer, high grade bolts to mount them as I'm still running the stock safety restraints
#9 |
I ment the shoulder ones but then I looked at your pictures closer and saw you had the wrap style on the bar. Im sure Ill figure something out, if I even end up getting one.
