my ongoing struggle
Hello all this will be an ongoing thread of my struggle with my fd3s and its build
I bought this car about two months ago. This is my second rotary powered vehicle. My first was a 1988 NA fc3s. I loved the car until it popped and I sold it. So now I have a 1993 Fd with touring package. the vehicle was modded prior to being purchased. Mod list done by previous owner)koyo radiator FAL fans and shroud kit mishimoto radiator hoses ApexI pod filters smog delete xs power LSMIC megan street coilovers ApexI down pipe and full exhaust with high flow cat ApexI power fc unknown carbon fiber hood hot water labs headlights (removed) enkei 17's with crazy large tires Mod List: ( I have done) dangdrifters intake piping one off 17'' gram lights In the works: DangDrifters crossover tube DangDrifters compression tube & elbow DangDrifters AST DangDrifters full 3" catless exhaust Ogura Clutch DangDrifters full cage various gauges big country labs wing Cons: needs multi switch needs random misc parts yucky paint needs headlight covers At the moment my car is at my buddy's shop for winter storage as well as getting some much needed maintenance. My buddy Russel owns DangDrifters in New Hampshire and is fabing up a bunch of one off parts for the car as well as doing an overhaul of the vacuum lines and cleaning up and sealing of the grounds. In the spring after the car is all buttoned up it will be heading over to granite state dyno for a nice tune! the compression is 105 in the front and 100 in the rear which I am a little bit worried about but will hopefully be deciding what to do about that soon. I was thinking NA because im really into NA and wouldn't mind a 20b na or even some type of newer 13b NA. But most likely a fresh 13b REW since I have already sunk so much time and money into the engine bay ei custom piping etc. So for now I will try to update and progress on this build and pictures!
Sean B. 1993 FD3S Touring |
#2 | |
Rep Power: 17 ![]() |
The struggle has just begun!
Update: ordered greddy throttle body elbow! Will have the compression pipe made when it gets in.. I got a hell of a deal! 99 bucks
#4 | |
Mazda dealers have an officially revised spec of 60 - 65psi for a "good" motor. -Ted |
#5 | |
. 60 65 makes me feel much better! Thanks
#6 | |
Professional Stick Poker
You can't believe everything that the french models post on the internet.
#7 | |
I think your 100 - 105psi readings are damn good for an FD 13B-REW! Enjoy your motor for a while! -Ted |
I'm gonna have some good old fashion fun when it's done. I Wanna do time attack!
#9 |
Hey long time no post. My car has been in storage all winte while i gather parts. I just got my Pettit limited ecu and installed that and two boost gauges with a buddy of mine. We started the car and took it for a ride to set the boost. The gauge i had wasnt working right so we brought the car back to his shop to swap out the boost gauge. On our was to the shop it started to idle very low between 200 and 500 at standstill. Once at the shop with the hood open we realized that when the coolong fans went on the engine would idle as mentioned 200-500 rough idle. I went to turn the car around to put it in a spot and it died. It would not start , i checked the plugs to see if it was flooded but the plugs were dry. The plugs were black as night but i dont think that would cause the idle issues under load. It could be the altenator but i cant test it since it wont start.also when the car died the fog lights cam on and wouldnt go off! Im thinking bad grounds? Altenator? Anyone experience this befor?
#10 |
Also as an update. I have over the winter installed my gram lights and nrg wheel . On order i have the oem front lip.
