Old 06-22-2013, 07:25 PM   #1
88turboii
destroy, rebuild, repeat
88turboii's Avatar
im back in an FC!!
i ended up junking my last FC becuase of rust damage and multiple rust holes in the body causing fumes to be sucked in the cabin, and it was basically a piece of crap. I then found a good deal on an FD, built it up, but never really liked it that much. Started looking for another FC and a friend hooked me up with this 1986 FC without engine or ems. it has manual rack, manual windows, LSD
i still have all the parts from my last fc.. tein's, S4 TII block, 60-1 turbo, sideskirts, S5 bumper, etc.. im going to swap all those on and use it for drifting and track days. and repaint it white. im going to try to do it on a factory ECU too.. AFM tuning
Old 06-22-2013, 08:05 PM   #2
chibikougan
chibikougan's Avatar
Looks Fun.!
Old 07-04-2013, 05:44 PM   #3
88turboii
88turboii's Avatar
i tore out the interior last weekend, smelled like dog piss and i found a couple rats nests in the process
here she sits with shocks and brakes removed..
out with the old, in with the new. TII brakes F+R, TII slotted rotors, Tein Flex coilovers
I went through my spare engine parts and pieced together a stock port S4 TII block.. rebuild parts are on order, going with RA apex seals
Old 07-06-2013, 09:14 PM   #4
88turboii
88turboii's Avatar
rebuild parts came in today
Old 07-08-2013, 09:49 AM   #5
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
You could have had an SA!
Any chance you'll have it ready for B3R?
You can always get parts from your brothers car! LOL!
Old 07-10-2013, 08:30 AM   #6
diabolical1
I have radioactive semen
there's just something about looking at a bunch of new parts.
Old 07-21-2013, 08:24 AM   #7
88turboii
88turboii's Avatar
i htink it should be ready for b3r
the block is mostly built, just a stockport s4 TII block made with spare parts. instead of oem coolant seals, i used .093" square viton cord just to see if they work out also went with turblown's stud kit
Old 07-21-2013, 10:39 AM   #8
How was installing the turblown stud kit? Pretty simple to just swap em out for the tension bolts and call it a day?
Old 07-21-2013, 10:49 AM   #9
88turboii
88turboii's Avatar
yes super simple, they are threaded on both sides, but have an allen wrench fitting on one end to make it easy to thread into the front iron, then you just torque the nut to spec
Old 07-21-2013, 02:55 PM   #10
Sweet, didn't know if they were stock sized or if milling was needed. I will probably go this route on the next engine I put together....
Old 07-21-2013, 10:55 AM   #11
I need another FC in my life. Been heavily considering it for a track car.
whats the plan for this one?
Old 07-22-2013, 07:04 AM   #12
88turboii
88turboii's Avatar
yes its a track car. my only complaint is it has a sunroof and i cant fit with helmet, need to take it out
i was going to assemble the front cover stuff yesterday, but i used a GSL-SE e-shaft and cant find the front bolt for it, ended up ordering one from mazdatrix, so will have to wait
also, i found a haltech e6k.. so new plan is to try to run two ID2000 injectors and block off the secondaries. hopefully i can get it to idle and cruise on the 2000's and not have to deal with staging problems. the fuel system will be pretty simple with just a single rail, i will probably run an a1000 regulator, and a walbro 400. im going to try to keep the factory resistor relay for knocking down the voltage at low loads. Also going to run FC coils with bosch ignitor
Old 07-22-2013, 07:20 AM   #13
88turboii
88turboii's Avatar
haha exactly
Old 07-22-2013, 07:10 AM   #14
so you have the "im too tall for Rx-7s, but I like them too much to worry about "safey"" thing i do.
Old 07-22-2013, 09:13 AM   #15
RedR1
Brokeback Power!
RedR1's Avatar
RedR1 will become famous soon enough
wewt!! keep the progress pix flowing. I love watching projects come together
RedR1 is offline   Reply With Quote
