Rep Power: 14 ![]() |
Fuel Pump Issue GSL-SE
Ok, I have searched high and low to find an after market fuel pump that matches to one in my 1884 GSL-SE. The one in the car has a banjo fitting on the outlet that is secured with the pressure regulator. This banjo fitting allows the outlet pipe to do a 180 to go back to the stock filter.
All the ones I have found look close but they do not use a banjo fitting. I have not found a hose fitting to attach to those threads. Any love here? |
Never mind, I see how it works now. All of the ones I have looked at will work with the banjo fitting. I was expecting a hole in the fitting on the pump. The fuel passes into the regulator and back into the banjo fitting. Guess I had better get a new pressure regulator too.
#3 | |
I have radioactive semen
![]() okay ... you know i had to, right? ![]() seriously though, i'm glad you got sorted out, bro. |
