Old 09-01-2012, 08:40 PM   #1
Viperx7
Viperx7's Avatar
Viperx7 is on a distinguished road
Question 89 GTU problems
I picked up an 89 Rx7 GTU w/automatic trans and after doing an engine rebuild, when you put it in gear, it bows up like it wants to move and dies. Put it up on jackstands and it will go in gear and run, but shakes like crazy.
Changing to manaul is out of the question. Person I bought for can't drive manual.
Here is how the car is:
The car sat for 3-5 years. Bad engine.
Fresh rebuilt engine.
header no cats.
6 port actuators don't work. Port sleeves are closed and actuators and actuator rods have been removed. So much carbon in the sleeves and actuator rods, 1 rod broke. Couldn't get the rods to loosen up. LIM was welded up where actuator rods were. All vacuum lines capped or rehooked up.
Air pump blocked off.
Rtek computer w/eomp delete.
Haven't changed tranny fluids,filter or modulator valve yet.
I don't know the maintenance history on the car, but probably pretty bad. The engine had more carbon in it than any engine I've ever seen. My friend that built the engine(Drama) said in all his years, he had never seen anything like it. Tranny fliud/filter may be original for all I know.
Talked to a mechanic friend and he says it sounds like the clutch packs are frozen.
What about bad driveshaft?
Flat spotted tires from sitting? We pulled the car to his house(about 1 mile), he said they were but got better as we went.
These would explain vibration but not dying.
Sorry so long, any help is greatly appreciated. Hope I covered it all.
Mike Chrisman
83 Rx7 Turbo
85 Rx7 GS
89 Rx7 GTU
http://www.cardomain.com/ride/409797
"Don't apoligize for being Patriotic, F**k 'em. TK"
Viperx7 is offline   Reply With Quote
