Old 02-25-2008, 01:54 PM   #1
Car's going into limp mode..
This past weekend, i went on a small vacation...
On my way after about 140+ miles the car started to stumble and I lost power. Eventually, I came to a haul and I was able to start the car.. But soon as I started to move I couldn't accelerate past 3000RPM.
I reset the ECU and I was able to make it to the next exit, filled up the gas, and the car was fine for 2 days. Then I was coming back yesterday and I had the same issue... No engine light, no TCS, no DSC, etc.. Just starte to stumble like it was running out of gas and eventually the car died. I could start the car fine, drive up for 15 sec or so and it would start again.. until fill up the gas and reset the ECU.
It was quite weird?? Anyone have any ideas? I was thinking it could be the fuel filter but I could drive over 100 miles without issues.. I just can't pin point the issue. I drove the car to work today and it was fine. Not a single issues.
Old 02-25-2008, 06:11 PM   #2
fikren
fikren's Avatar
fikren is on a distinguished road
I assume your cars out of warranty? Is the ecu flashed with current versions? Wouldn't think it would be the filter if you were able to get 100 miles out of it, maybe got some bad gas and the new gas you put in may have worked it on out.
Wonder if the ecu is throwing any errors that arn't showing on the idiot lights.
Could it be an injector problem?
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
Old 02-25-2008, 07:14 PM   #3
Well, before I got the car, it had the latest flashes and such. And its so out of warrantee
regarding gas, I drove from Bham to MS without an issue (190 miles from fill up).
once I reset the ECU, everything seemed fine.. and filled up again and drove total of about 300 miles. It wasn't until third fill up and 150 miles later that it went into this limp mode.
This time I watched the cluster to see if any lights were blinking and such... NONE!
I thought it might be something to do with ignition but after reset, everything is back to normal. I could get up to 90+ mph without an issue... So, I don't think its injector..
I've heard something about gas cap issues but don't know what that does??
Old 02-25-2008, 07:30 PM   #4
fikren
fikren's Avatar
yeah I read about the gas cap issues but i didn't read what it was all about since it didn't effect mine. If I'm not mistaken it was for certain vin# groups. Might look into that, it was a recall thing dealer would have to get you a spanking new gas cap if yours falls into that grouping, not too sure what it would affect though other than maybe pressure loss??
93 bb rx7
Proton Fushmounts
Sato Rearsets
Old 02-25-2008, 09:28 PM   #5
Yeah, I don't think its the gas cap.. Maybe filter? I have no clue why its doing what its doing..
Everything seems ok today.. Very weird.. I changed the oil today and this weekend, I'm going to change the sparks.
Old 02-28-2008, 01:04 AM   #6
BBullet8
BBullet8 is on a distinguished road
I have had that problem but it is more around 4500rpm. I have found that when my intake is cracking there is air escaping and not being sucked in and I have a major loss of power. I have also found that when I add oil if i add it after running the car really hard it does the same thing. it always goes away but i have no idea what causes it.
BBullet8 is offline   Reply With Quote
Old 02-28-2008, 04:54 AM   #7
blwnrtr93
blwnrtr93's Avatar
blwnrtr93 is on a distinguished road
One of the guys at work was telling me that his gascap on his truck wasn't tightened down all the way and it threw a code which put it into a lower power state until he had the code reset.
blwnrtr93 is offline   Reply With Quote
Old 02-28-2008, 07:46 AM   #8
So far I haven't expereinced it since coming back home. I been looking thru the car to figure something out but nothing.. Everything looks good, starts fine, idles fine, and nothing.. I guess I might have to go on a trip somewhere and experience it again. I'm going to take this to Cheeha and see if it happens there..
PHIL
Old 03-02-2008, 10:52 PM   #9
Sounds similar to a friend of mine with another '04 - took it to the dealership and it turned out to be his coil pack - check that out (this is the reason I kept a spare set)...
Old 03-03-2008, 03:12 PM   #10
Kevin,
Awesome! I did not know you could use FD plugs in the 8?? Awesome! I have like gazzillion FD plugs at home.. Dont mind changing every 10k
I'm doing Catback replacement in next month or so.. i'll check the cat too. But I don't think its the cat.. Since the trip, Everythings been OK... No issues.
I reset the ECU by unplugging the battery, and press the brake.. I used this technique when my Acura used to have misc warning lights pop on... I think it worked on the 8 also... I think?? because I just unplugged and waited 20secs and didnt do shit! LOL!
Old 03-03-2008, 03:29 PM   #11
Rotary Inspired
Rotary Inspired is on a distinguished road
My guess would always start to be w/ ignition and spark plugs. Mine need to be changed on my 05 soon.
I hope you get it sorted. Please post what you find.
If you wanna become ASE certified buy the RX7.
Rotary Inspired is offline   Reply With Quote
Old 03-03-2008, 09:41 PM   #12
fikren
fikren's Avatar
reseting procedures pulled from another website
"There are two reset procedures, one for the NVRAM and the other for the KAM. Neither will erase your radio presets and such like the method XXXXXXXX posted:
1) With the key in the off position, press and hold the odometer reset button and turn the key to on;
Continue to hold the odo button until the odometer reads "TEST" and then release.
2) Turn the key to off and repeat step one.
This will reset the entire PCM except the KAM which contains the sensor profiles amongst other things. You can reset it with the familiar procedure:
1) Turn the key to on
2) Depress the brake pedal rapidly 20 times in a row until the oil pressure gauge sweeps to halfway and back again."
93 bb rx7
Proton Fushmounts
Sato Rearsets
Old 03-05-2008, 08:39 AM   #13
1twistedrx7
1twistedrx7's Avatar
+1 for Johnathon
by the way how is the 20b project going on ?
93 vr touring sold
93vr died violently
93 ssm touring sold
underestimated !!
http://rotorfest.lefora.com
Old 03-05-2008, 10:39 AM   #14
fikren
fikren's Avatar
Originally Posted by 1twistedrx7. View Post
+1 for Johnathon
so far its going nowhere, waiting on the Work wheels I ordered to show up (hopefully next month) so I can get the car to the body shop plus picking up this 8 put a damper on the available funds plus a trip to Japan thats in the works. I'm estimating my time frame to be 2-4 years
93 bb rx7
Proton Fushmounts
Sato Rearsets
Old 03-04-2008, 01:50 AM   #15
Interesting.. I have to give that a try!
