|  06-14-2011, 04:06 PM | #1 | |
| RCC Contributor Join Date: Mar 2008
				Rep Power: 18  |
				S5 Oversized Stat Gear Bearings?
			I was at my local Mazda dealership ordering stationary gear bearings for a S5 13B and the parts guy found two different types.  Standard and Oversized. The parts guy did not provide many any hyphens between the numbers so I'm typing them identical to what he gave me. Standard 082010502B Oversized N35010E02 (though I can't read his writing and it might be N350010EO2) I found that I need standard through surfing Mazdatrix website. Their part numbers are partially reversed but identical other than that. Mazdatrix 10-502B-0820 I expected the dealership's standard bearing to match and I expected the oversized to be the 3 window race bearing. But the part numbers don't match. Mazdatrix 3 window 11114 I'm just trying to figure out what the oversized bearing is? Obviously I see the N350 in the part number. I'm also looking at the FD bearings that are offered in different thickness. The thinner FD bearings have part numbers 10-E040....very similar to the 10E02 at the end of the oversized part number.
				__________________ Quote:
 1990 Vert/ S5-JDM 13BT (rebuilt but with issues I'm working out). Rtek N370 1.7, 550/800 injectors, FD fuel pump, RB REV TII exhaust, Tein springs and Illuminas | |
|  06-14-2011, 04:23 PM | #2 |
| RCC Addict Join Date: Mar 2008 Location: Honolulu, Hawaii USA
				Rep Power: 19  |
			FC stat gears bearings only come in two sizes from Mazda - standard and oversized. Oversized is for those who have a "clearanced" eccentric shaft due to machining in case of warpage / damage. Unless you have the tools to "mic" the eccentric shaft - v-blocks, run-out gauge, calipers, etc. - just get the standard bearings. Most people should just get the standard bearing. Mazda went one step further with the FD stat gear bearings - that's why there are several (+ and -) to account for variations in production tolerances and for slight clearancing machining. (I think it's something like one or two undersized, one standard, and the rest are oversized.) I guess they thought clearances on the stat gears was that much more critical on the 13B-REW engines... -Ted |
|  06-14-2011, 04:33 PM | #3 | |
				Rep Power: 19  | Quote:
 All Mazda parts are grouped by: XXXX - YY - ZZZZ So "082010502B" is "0820-10-502B". YY = location of part, which, in this case, 10 = engine "0820" is year / model designation? Since it's 4 numeric, this means application over several years / models? "502B" is the sub part # under "10" = engine. The "B" at the engine is a revision letter, which just means it supercedes an "A" part. So "N35010E02" is "N350-10-E02". "N350" is 1989 - 1992 RX-7. "10" = engine "E02" = sub part # under "10" = engine. Mazdatrix just rearranges the Mazda PN's for easier sorting... "10-502B-0820" is... "10" = engine "502B" = sub part # under "10" = engine "0820" = year / model designation We got a Mazda parts tech in the house?  j9df3s still around?  -Ted | |
|  06-15-2011, 12:26 AM | #4 | ||
				Rep Power: 18  | Quote:
 I was actually expecting j9df3s to be the first to answer
 1990 Vert/ S5-JDM 13BT (rebuilt but with issues I'm working out). Rtek N370 1.7, 550/800 injectors, FD fuel pump, RB REV TII exhaust, Tein springs and Illuminas | ||
|  06-23-2011, 03:39 PM | #5 | |
| Rotary Fanatic Join Date: Mar 2008
 that explanation is exactly right. just to add the application part of the part number, is the car it was originally engineered for, so 0820 is the R100 10A engine. N350 is the non turbo 89 rx7, etc etc. its not a hard and fast rule, there are exceptions. 10 is the engine block, 13 is intake exhaust, 15 is the cooling system etc etc. the next 3 tell you what part it is, and in theory 15-200 is always a radiator, 13-111 is always an intake manifold gasket, but again, they change things here and there. the supercession code is pretty meaningless to the consumer. sometimes the part is clearly different between A and B, sometimes it can be a price change. i have also seen revisions change the application part of the part number, the good example of this are the FD front iron housings. they start with an N3A1-10-whatever, and go to N3F1 and N3G1 as they get updated... oh and an R or R-01 means its a remanufactured part we got to tour the volvo factory, and you guys should see the press dies for the body parts, they are like small trucks! it takes something like 4 hours to switch dies in the press.... | |
|  06-15-2011, 08:06 AM | #6 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |
			Buy renni gears/e-shaft   MT part numbers aren't completely accurate to the Mazda OE part numbers. But after dealing with it for years, it's pretty easy to know which numbers they add to keep thier sorting in line. Seriously, Front gear and bearing, $110, rear gear and bearing, $140. Stock bearings $25, hardened multi window that you get with the renni, $55. Soooooooo basically $140 would've ended all this hassell.
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  06-15-2011, 07:21 PM | #7 | ||
  That and I"m keeping the rebuild as simple and close to OEM as possible. When my finances improve I'll pick up a core engine and look to build something more fun. Once I have the car up and running on a reliable engine that frees me up to risk trying mods and other dangerous science.
|  06-15-2011, 08:38 PM | #8 | |
				Rep Power: 10  | Quote:
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | |
|  06-15-2011, 11:31 PM | #9 | ||
|  06-15-2011, 11:51 PM | #10 |
				Rep Power: 10  |
			I don't need mine much either.... but when I need it.... I NEED it.  Same goes for the tubing bender I'll be buying shortly
|  06-16-2011, 01:57 AM | #11 | ||
|  06-16-2011, 08:02 AM | #12 |
				Rep Power: 10  |
			Good thing you're not handleing my logistics.... why would you need new RX8 gears with a new bearing already installed AND a press????
